Question about Sewing Machines
I can only use a pes format. Can all my purchases be formated in pes?
Baby Lock PR600 Next color of stitching does not start in the right place
Is this happening only when you stitch a particular design/pattern? If so, the issue could be an error originating in the design. Sometimes designs are digitized on commercial software with commands intended for industry machines and when the design gets converted to a home format like PES via various conversion programs, the command gets misunderstood. Try reconverting the design again, or contact the digitizer of the design and request they review the design for any errors and create a new PES file for you. Note, there are 10 versions of PES at this time and your machine should be able to read PES version 4 without issues.
Jan 08, 2015 | Baby Lock Sewing Machines
I am not sure the program has downloaded on Windows 7. The embroidery designs will not move there--
Sometimes embroidery files download in ZIP format.Check your download folder, and double click on the downloaded file. windows shoukd extract it into a folder of its own. open that folder and the .pes files should be in it. Then open the Brother program to access that folder with the .pes files.
Sep 27, 2014 | Brother PED-Basic Embroidery Software w/...
Embroidery design format
Babylock machines use the "pes" format.
Jan 03, 2013 | Baby Lock Esante
WHAT IS THE BEST FORMAT FOR IMPORTING EBROIDERY DESIGNS
Each kind of embroidery machine will import differently; Bernina uses an ART format and only that. Many collections (designs) are multi-formatted with ART, PES, HUS, ***, etc. Your machine will embroider best with a specific format - your dealer should be able to tell you which one to use. If that is not possible, pick an easy/small number of stitches design and try several formats to see which one stitches out best.
Feb 04, 2012 | Singer CE-200 Quantum Futura Computerized...
I just purchased a pe770 Brother embroidery machine. Do I need anything other programs to download patterns, from my cp, to my flash drive, to use with this machine?
All you need to know when you purchase designs from the internet is that your Brother PE770 will only recognize DST and PES formatting. There isn't anything else!
Aug 03, 2010 | Brother PE770 Computerized Sewing Machine
Have a se270d and just purchased ped basic. Put designs on card and put card in machine, but it won"t read the card at all. No error message or anything, but it does recognize there is a card present....
Check the design size and format.
The 270 is limited to a 4 x 4 hoop and the design must fit inside this measurement without the foot hitting the hoop.
The format must be pes
Mar 12, 2010 | Brother SE-270D Computerized Sewing...
Embroidery designs
Futura software can read most of home embroidery formats. Because the software was developed by Compucon, you might want to prioritize XXX format. Other common formats such as PES or DST will also work great with your Futura machine.
Mar 31, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
