Question about The Watches
How do I fix the seconds on my M.Z. Berger watch to match the satellite so that I have the correct time? My watch is 11 seconds slow. Is there a way to fix it?
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Tropby radio controlled watch, runs slow, even with new battery
Your watch is need to clean an replaced the old oil in gear shafting that is the common problem of a watch when the old oil is sticky already thats makes the gear moves slowly and your watch is always late . If ever your watch was already clean and replaced new oil and still working slowly then the problem is in the circuit board is near to run out its needs to replaced whole circuit board so its better again. I know this because im a technician in Rolex service center before. Feel free to ask whatever the result.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 30, 2009
  • 2501 Answers
SOURCE: tissot touch watch, the digital time is correct, the analog not.
You can get a set of instructions from their web site (tissot.com).
At the bottom of the page there is a menu; select "warranty" and a number of alternative PDF files appear on the left.
If you can't see what you want, select "user manual" from the menu at the top and enter the details of your watch.
Choose the one that is suitable for your watch and download
Posted on Mar 21, 2010
Testimonial: "this is the conclusion that i also came up with."
  • 184 Answers
SOURCE: When I pull out the crown to the second place, the
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Posted on Sep 16, 2010
Testimonial: "Bill was "Spot On" with his well laid out explanation. Thanks for getting me straightened out! The link to the instructions was fantastic too!"
Am....guys i want to know if my watch going 2 minutes back it will be forward after 28 minutes???and how can i fix it?? **its 2 minutes back 4 hours now.my watch is a jaga wr100m orange
You aren't making a lot of sense with this post either. This is a normal quartz watch. It isn't connected to a time server, so you need to correct it.
In the image, the watch says it is 9:41. If the correct time is actually 9:43, you advance it 2 minutes. You say 'back', but the better terms for a watch or clock are 'slow', or 'fast'. Your watch is 2 minutes slow, or two minutes fast? If the correct time is back, (the watch is fast) you need to advance 28 minutes.
Post here as a COMMENT, DON'T start a new post!
Feb 08, 2017 | Watches
How to set time on m.z. berger wrist watch
Hi Hollywoo,
As far as I can see Berger watches all have what I would call a winder knob. You normally pull this out gently and then turn it to move the hands of the watch - ie: to set the time. When finished just push it back in.
Aug 08, 2015 | Watches
How to set the time on a digital watch
Hi, you need to find the little black "set" button which is located on the right side of the watch between the two functioning buttons. its very little. Press it once with like a needle or a pen tip (because you cant reach it with your fingers). You can then set the time.
Jan 12, 2014 | Watches
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 | Watches
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
B
ALARM
main time hands.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
My Ebel (9187241) is now 11 years old. Recently...
The 4 second ticking indicates the battery is in need of replacing.
A professional watchmaker can properly replace the battery for you.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 20, 2010 | Ebel 1911 1087221 wristwatch
Casio 4305 runs 5 minutes slow.
No reason to panic as your watch hands can be advanced to desired time. Her is the link for your watch users manual download:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4305&submit.x=52&submit.y=12
Save it on your PC and follow instructions how to set the time.
Don't forget to rate, please.
Jan 05, 2009 | Watches
Fix the hands correct with the dejital
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are;
hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t
have the hands exactly opposite etc. This can all be fixed. The Synchronization
function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Nov 16, 2008 | Tissot T-Touch T33759851
Watches Logo
24 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
