Question about Briggs & Stratton Garden
Engine wont start, runs on a spray of parts cleaner then dies,
    President:
  • 1,273 Answers
Hi. Establish that you have good flow from the tank to the carb. If NO, work backwards to the tank. If YES, clean the carb. Use brake cleaner, and pay particular attention to the orifices.
Best regards, --W/D--
Posted on Jul 25, 2009
Car starts and runs for bout 20 sec then dies starts right back up but wont stay running
Try spraying some starting fluid or carburetor cleaner into the engine an see if it will keep running ! Have you tried holding the throttle open a little or are you just letting it idle ? Any lights lit on dash , check engine ?
Mar 23, 2015 | 1997 Buick Skylark
2006 buick rendevou starts then dies
If the car will not idle (starts and dies) but will run if you keep your foot on the gas, you have a vacumn leak. It could be a broken plastic fitting on the intake or a crack in the intake.
If you can get the car running, spray carburetor cleaner around the components on the engine and if the engine speeds up you have found the problem part.
Sep 07, 2014 | 2006 Buick Rendezvous
1992 acura integra wont stay running
Try the procedure below.
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Jun 30, 2017 | 1992 Acura Integra Hatchback
How do you clean EFI ON A 4.3 V6 ON MY 1989 C-1500 2 WHEEL DRIVE
remove the air duct hose that goe's to the throttle body, then you can see the throttle body area, you can purchase throttle body spray cleaner from a auto part store, start vehichle up and let run, and while holding down on throttle so engine won't die, gradually spray the cleaner into the throttle body area, and continue to let engine run untill smooth, so that the cleaner that was sprayed has time to burn the excess off of the o 2 senors, if engine light comes on after this, shut off engine, and disconnect 1 of the battery cables for about 1 minute, then reconnect the cable, and start engine up, light should be out, but later , i would hook up a code tester to the aldl under the instrument panel on drivers side to make sure code # from the light being on was removed, hope that this information was helpful to you.
Mar 05, 2011 | Chevrolet C1500 Cars & Trucks
How to clean the throttle body on a 1999 cougar
u can spray throttle boby cleaner on the throttle plates if it is sticking closed but if u want to do a real good job of cleaning it take it off and do it
Feb 25, 2011 | 1999 Mercury Cougar
My blower wont start. untell i spray carb cleaner in it then it will run for a few seconds then die again
Need to have the carb cleaned/rebuilt. Local small engine shop can sell you the kit you need or you can dis-assemble and clean and put together. Go very slowly and make note of how all the gaskets/diaphragms come off. Should only do 1 side at a time so as to not mix up gaskets/parts.
Oct 22, 2009 | Garden
My yamaha ttr 125l wont start it keeps turning over and then dying like it has no gas but it has lots any ideas?
too much fuel will cause same symptoms, grab a can of car throttlebody cleaner from the parts store, and pinch the fuel line off, and attempt to start till fuel is empty in the bowl of the carb, then spray cleaner in carb with the throttle full open 2 to 3 times close throttle, start, as it attempts to run spray slowley while engine runs, adjusting the flow as you rev engine.this eleminates poss bad gas or carb problems. if it runs fine this way then check gas, and check the carb. (while cleaning use a small wire to clean the tubes inside the carb as well, good luck!
Oct 13, 2009 | 2002 Yamaha TT-R 125 L
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
87 325 runs good when
It's the automatic choke!
The choke is "closed" or barely open... When cold, the engine needs a RICH mixture (more gasoline, less air). When the engine warms up, it requires a LEAN mixture (less gas, more air).
It is probably creating BLACK tailpipe smoke ... that means unburnt gasoline. (Blue smoke is OIL, white smoke is WATER).
Put the parking / emergency brake ON.
1. Remove air cleaner assembly from intake, use a carb cleaner spray or throttle body spray cleaner and spray just a little. (AutoZone $5)
2. Find the accelerator2.gif arm under the hood.
3. start car, rev the engine to make sure how to operate the accelerator from under the hood.
4. Carefully spray into carb / throttle body and work the accelerator ... don't let the engine die...
5. Watch out for "backfire"... it may create a small flame out of the carb. It will extinguish itself in one second.
6. You may need to do this two, three times.
7. Add a "complete fuel system2.gif cleaner" to your next tank of gas ($8).
That's it! ... pretty cheap, too.
Hope this helps!
Sep 04, 2009 | 1987 BMW 3 Series
Starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Apr 09, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
62 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
