Question about Singer Sewing Machines
My singer confidence not forming loop to pick up bobbin thread
    Master:
  • 995 Answers
Make sure the correct thread and needle are being used for the material sewn, and sometimes you have to re thread.
Posted on May 02, 2017
Please share the symptoms of a messed up timing on a Singer Confidence sewing machine. Thank you in advance
A timing issue is usually demonstrated by the needle thread failing to pick up the bobbin thread. First, try installing a brand new needle as a bent/damaged needle will sometimes also fail to pick up the bobbin thread. You can search the internet for sewing machine timing or take it for service.
Dec 07, 2016 | Singer Sewing Machines
Singer 8734 :my thread is bunching up under the fabric. How do I adjust the bobbin?
If the thread is bunching up, it sounds to me like the stitch isn't being formed properly. Nothing to do with the bobbin, more a case of timing.
The spike, or whatever it is on your machine, which is under the needle, must pass through the loop in the thread from the needle at exactly the right time.
When the needle reaches it's lowest point, as it starts to go upwards again,a loop is formed in the thread,next to the needle eye. This loop is what the spike must pass through in order to make the stitch.
May 19, 2014 | Singer Sewing Machines
Janome 611 manual com file 634d
upper thread tension needs tightening or timing adjusting.
Dec 01, 2013 | Singer Confidence 7463 Computerized Sewing...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
I cannot get the top needle thread to pick up the bobbin thread on a Singer 404. I have the manual online and can see that I have loaded everything properly, but the bobbin thread just sits there when I...
Hi Jennifer:
Do you understand how a stitch is formed on a sewing machine? The needle goes down to its full down position. At that point the shuttle hook should be pointing right at the needle scarf, ready to go past it as the needle starts to go up.
When the needle starts its upward travel it forms a loop... the shuttle hook enters the loop and the bobbin thread is "captured" in that loop.
If your machine's timing is advanced, the needle will hit the hook and break or make nasty thumping noises. If your timing is ********.... the hook misses the loop entirely and does nothing.
So... open up the entire bobbin/throat plate area.... take the foot off so you can see. Clean if necessary. Then turn the hand wheel by hand until you see that the needle is at the lowest point of travel. Where is the shuttle hook?
From there you'll have to use your logic to find the right screws and adjust the hook.
Here' is a Parts Chart for your machine.
http://www.parts.singerco.com/IPpartCharts/404-1_4_5.pdf
Sep 14, 2012 | Singer Sewing Machines
Singer confidence 7467 bobbin thread issues
Have you checked that under the foot plate is clean sometimes a bit of fluff or thread collects there, and are you threading the needle the right way. check with the manual for the machine. Also check which way the manual recommends the bobbin thread is unwinding clockwise or anticlockwise. Hope this is helpful,
Sep 03, 2012 | Singer Confidence 7467 Mechanical Sewing...
The needle won't pick up the bobbin thread? Seems
I think you mean the shuttle is not picking up the top thread. There are many reasons why this can happen. The best way to find out which is to leave the cover off the bobbin compartment and turn the machine slowly by hand while watching things happen for a few cycles - best to have a piece of material in place as well (but not in your line of sight).
As the needle begins to rise, the top thread should form a loop for the shuttle to pick up. If no loop forms, the needle could be too fat for the thread, the thread could be sticking to the needle, the pick-up arm could be out of time (unlikely), or the thread tension could be wrong (or the machine not threaded correctly).
If a loop forms, but the shuttle does not pick up up, the needle could be bent (take it off and roll it on a flat surface),or in backwards (loop forming opposite to shuttle), or the material (or your manner of feeding it) causing the needle to be deflected away from the shuttle. On some machines, it is also possible to loosen a clamp and move the shuttle closer to the needle, but obviously that is a last resort (unless it has come loose or been forced away).
There are other possibilities, but usually it's the simplest thing. Try changing the needle?
Jul 27, 2011 | Elna Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Brother ls2125 bobbin not picking up thread
OK...I have an old singer (from 1964) so I am not sure whether you can do this...
I thread the upper thread as directed.
I stick the bobbin in the bobbin assembly as directed.
LEAVING THE SLIDE DOOR OPEN...I, by hand turn the wheel on the right hand of the machine counter clockwise (towards me). I want the needle go down. The thread from the upper part will enter the bobbin area and will form a loop that goes OVER the top of your bobbin to catch the thread from the bottom.
I keep turning until the machine has complete a cycle where the needle has started from the highest point, dropped to the lowest point (thus forming the loop that passes over the bobbin) and returns back to the highest point).
At this point you will notice that the thread is coming for from the bottom of the machine..I use a scissor to pull the the ends of the thread through. To the top. There should be two ends, one from the top thread, one from the bottom. If you dont believe me..jsut use a bobbin with a different color of thread...you will see what I mean..there will be two threads...one the first color and one the second color.
Good luck!!
Jan 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
