Question about The Office Equipment & Supplies
I need the answer key for b.6 - The Office Equipment & Supplies
Got the Bosch Classixx 6 1400 Expresswashing
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
My problem involves converting in chemistry and im just trying to figure out how to do a problem 0.58 x 6.022 x 10 raised to the 23/ 1. I know how to calculate the problem just cant read the answer a more...
Press the keys:
. 5 8 * 1 2 . 0 1 x^-1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
and you should get 2.9E22. Do you get something different?
* is the multiply key on the right, between divide and subtract.
x^-1 is on the left, below MATH.
EE is the 2ND function of the , key, just above the 7.
Another way to calculate this is:
. 5 8 / 1 2 . 0 1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
This should give you the same result.
Mar 10, 2010 | Texas Instruments TI-83 Plus Calculator
How can I use the Log function on my calculator?
Hi ;
for log base 10 use the the "log" key
example :
log(2) + log(3) = log(6)
enter 2 press the log key you will get 0.30102999 press the '+" key than 3 log you should get 0.47712125 for it Press the "=" or enter and you should get 0.778151250 for a answer than press inv or 2nd log and you should get 6 for a answer
and that all there is to it
Oct 07, 2009 | Texas Instruments BA-II Plus Calculator
For ge 25942ee4 5.8 ghz - i can't locate instructions. need to know how to correct the day and time on main base phone.
1. Make sure the answering system is ON.
2. Press fash/answerer/call waiting button on the handset to enter answerer remote
mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confrm the setting.
Sep 30, 2009 | GE 25952EE1 Cordless Phone
Key pad does not always open door
It sounds like the contacts on the keypad are going bad. A new opener with the wireless keypad is the answer.
Sep 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to turn off transfer callback on Norstar Meridian
Ok, well I can explain most of the programming template, but I cannot give you the exact buttons to push since each phone IS programmed differently.
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail (record this number) and then RLS
-> now I need you to dial FEATURE 0 on your set, and press the Intercom key to ensure the extension of your set you want to change and then hit RLS.
To get into programming press FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will see 3 arrows on your LCD
<- Heading Enter->
<- Back Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change.
-> you should now see the extension of the set and the name that is associated with it, press Enter (the top right arrow key) again
-> now you will see LINE ACCESS and press Next (the bottom right arrow)
-> then you will see CAPABILITIES and press Enter. now you will see FWD NO ANSWER and press Enter, and put in the DN of the voicemail you saw with the Feature 985
-> hit Next for the number of rings you want to ring at the set before going to voicemail.
-> hit next and you can now RLS to back out of programming.
Voila, that set once called will now goto voicemail.
-OR-
You can get the receptionist to dial FEATURE 9 8 6 and the extension to transfer directly to someone's voicemail.
Apr 13, 2009 | NorStar Meridian M7310 Phone
How to set date and time
Voice Time/Day Stamp
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
Fax feature
You have to set the printer to pickup 2 rings higher than your answering machine. If the answering machine picks up on 4 the printer should pick up on 6.
I believe the menu should be Setup button - down arrow key until you see basic fax setup and press ok - down arrow key until you see rings to answer and press ok - change to 2 higher than answering machine.
Now you should receive faxes and calls!
Jan 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a uniden answering machine and i want to change the
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
i downloaded the owners manual from uniden at the link above , and from what i see its on page 26 of this pdf manual ,
enter the answer set up menu , and then the ring time sub menu , press volume up / down to select a ring time ( toll saver , 2 times , 4 times or 6 times ) then press the "OK" soft key , you will hear a confirmation tone . good luck
Dec 21, 2008 | Uniden TRU8885 Digital Answering Machine
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
