Question about The Office Equipment & Supplies
Solve the answer to 5.3x1.26= - The Office Equipment & Supplies
Paper jam unable to print print 73 error how to solve it
I have same problem, the message make me wonder. I am very sure there is no paper tears in the printer. But then i have the answer from internet. I hope this answer can solve your problem too.
First shutdown your printer and open printer cover and find something like ribbon plastic transparant. becareful,clean that gently use wipe tissue or alcohol tissue. dont touch with your finger. hopefully it can solve your problem.
Oct 03, 2016 | Brother DCP-J315W Inkjet Multifunction...
I am not satisfied from faxia answer
Hi Fazli:
- FIXYA answers are from people who are trying to help solve a problem.
- Sometimes we don't understand the problem from the way the question was asked.
- Sometimes we try to answer what we think the problem might be because the answer to the question will not necessarily solve the problem.
- Be assured, all the time we are only participating because we enjoy trying to help. Ownership of the problem is important. It is YOUR problem, not ours, and we are only trying to help.
- If you don't like the answer, that's fine. You have the ability to try to solve it yourself, or to hire someone and pay them to fix it.
Cheers.
Dec 04, 2015 | Cell Phones
I want to know how to solve the Cubic equation on TI-89 Calculator
There are a lot of ways to do it. One is to write a program using the cubic formula. If you just want the roots, use the solve() or zeros() functions.
For example, to find the zeros of x^2-6x^2+11x-6, enter
solve(x^3-6*x^2+11*x-6=0,x)
or
zeros(x^3-6*x^2+11*x-6,x)
Note that solve() has "=0" in it while zeros() does not.
solve() will give you an answer of
x=1 or x=2 or x=3
while zeros will give you an answer of
{1 2 3}
which plainly are the same thing, just expressed differently.
May 09, 2011 | Texas Instruments TI-89 Calculator
5/4x-18=-3 Ti 84 plus One: just press enter/solve Two: press 2nd Test (Math) then press enter Every time I put in and equation using the above method for the equal sign. it either takes me back to...
If you wan to solve an equation using the SOLVE feature you enter it as follows (your example)
You should rewrite it as 5/4*X-18+3 (= 0). Implicitly, the calculator assumes that the right side is ZERO and you do not enter any right side nor an equal sign.
Type in
5/4 [*] [X,T,theta, n] -18 +3 [ALPHA] [ENTER] (SOLVE)
You should get an answer -780/47 or the decimal equivalent (depending on display mode.)
Feb 12, 2011 | Texas Instruments TI-84 Plus Calculator
Changed network and now the internet wont work
iewty
changed network and now the internet wont work
Solve this problem: Enabled Pocket PC... Is it possible to install Android on the X500 instead of Windows Mobile? Close Answer Bid Solve this problem: what type of memory card does xda ii use?
Oct 26, 2010 | LG KU990 Viewty
Using each of th e numbers 1-9 once, fill in the ''blanks'' below. abc +def ______ ghi I don't just want an anwer.........how do you figure it out!
Answer 1:
1 9 2
6 4 5
8 3 7
Answer 2:
5 9 1
2 7 3
8 6 4
There are multiple answers right to this question. You can even interchange the numbers (up and down) in the given answer to obtain a new answer.
Now... how did I figure it out...
The best technique to solve this problem is trial-and-error, and not to use the brain much. If you use your brain to solve this problem, then there is no way this problem can be solved.
Jan 29, 2010 | Dk Multimedia I Love Math - 2nd (2071074)...
I wanted to know if the Casio fx-300MS can ratio problems
Sorry to disappoint you but there is no special key to (solve) ratio problems. It does however have a key to enter mixed fractions ( [a b/c] ) and a key combination to convert between mixed and improper fractions [SHIFT] [d/c].
Hope it helps.
May 06, 2009 | Casio FX-300MS Calculator
I can't solve some of the puzzles and I can't keep on asking for the answer so can you give me all the answers, if possible send to email only if it is for free plz and thanq-u.
Search for 'Professor Layton cheats' via Google or a similar search engine - you will get lots of websites that will offer answers to the puzzles you cannot solve.
Apr 11, 2009 | Nintendo Professor Layton & the Curious...
Before i pay iwant to know if you can solve my problem
Depends on the problem and you do not have to pay for an answer, you may just have to wait.
Dec 31, 2008 | Computers & Internet
How to use ti 89 with a problem like "-(3x+1)-(4x-7)=4-(3x+2)'
Just plug in one side of the equation and find the answer. Then plug in the other side and compare answers.
Feb 19, 2008 | Texas Instruments TI-89 Calculator
26 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
