Question about Sansui Audio Players & Recorders
Hi people I am looking for a manual for a sansui rz-3700 amp please!
I want to connect my sub and centre speaker!
  • 631 Answers
SOURCE: jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Posted on Dec 21, 2007
SOURCE: Technics SH-AC300 Connection to Power Amp & Pre-Amp
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Posted on Feb 24, 2008
  • 624 Answers
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
Posted on Jun 17, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Posted on Nov 06, 2008
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
Posted on Nov 08, 2008
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Aug 17, 2011 | Sansui RZ-5200AV Receiver
I have a Sansui RZ-7001 home theater system but cannot get surround sound when connecting my LG Blu-ray BD 550 to it. What am I doing wrong?
fred i dutoi,
Check your connections first. Make sure your input on the Sansui RZ-7001 menu is selected to dvd. Also, make sure the blue ray cables are also inserted in the correct inputs on the rear of the receiver(dvd input). via. rca cables(red, white & yellow) the yellow is the video, hdmi, or optical. If you do not hear sounds coming from your speakers you need to check the separate volume levels for the speakers within the receiver itself. Front and rears having different volume levels within the receiver. Hope this helps. Also make sure you check the volume on the dvd player. Thanks for visiting Have a great day !
Jul 06, 2011 | Audio Players & Recorders
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
32 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
