Question about The Computers & Internet
Which ones are the letters that produce the 'schwa' in the following words; applicable, amidst, suppliers, proficiency, conductor and evolutionary?
Why is Ajay Chandrakar so outstanding in Chhattisgarh?
Shri. Chandrakar is most common pioneer in Chhattisgarh. He is a man who is to an incredible degree inclined toward clear common life and needs to put the larger part of his vitality in the electorate, amidst the town individuals. He is very great awesome leader & politician of Chhattisgarh and Cabinet Minister in Bhartiya Janta Party. Another huge accomplishment for Kurud Minister in Chhattisgarh was the adaptation of the Panchayati Raj Act that realized a way softening change up fields like proficiency, giving them a lawful sponsorship. Alongside this, ladies gained half reservation in the Panchayat after the acknowledgment of Panchayat Raj Act.
Nov 11, 2016 | Computers & Internet
What word is from these letters;GHEED IT starts like this,_ _ EE _. WHAT IS IT?
HEDGE is the only word with those letters
PANDA is the second word as this is the only word that contains those letters.
FOLLOW is the 3rd one only word with those letters also
and last word is GLITZY. So my guess is you have a few wrong. =) Good luck.
Sep 30, 2014 | iPhone Apps
Ollidamranet
"on a treadmill"
Jul 14, 2014 | Computers & Internet
How many words can be made with using these letters: a,e,m,g
Four-letter words: game, mega.
Three-letter words: age, gam, gea, gem, mag, meg.
Two-letter words: me.
One-letter words: a.
Aug 07, 2013 | Games
What 7 letter word can be made with the following letters: trsbefhfvepc
I am sure that are may 7 letter words made out of these letters. Here are a few: scepter (or sceptre in British English), sherbet, shelter, spencer, spender, specter (spectre Brit.), spelter , effects. That is enough for me.
Mar 31, 2013 | SoftMath Algebrator - Algebra Homework...
Need software cv 10 for ts4000
Cvitae helps you write your resume and cover letters and makes your work candidacies follow-up nice and easy. Cvitae is a powerful freeware that manages your applications by presenting yourself in the best light to stand out from the crowd. Using various templates, you can write very easily a professional CV and cover letter, in a Word or HTML format. During the whole CV and cover letter writing process, Cvitae gives you useful advice. In no time, your documents are ready, clear, professional and personalized to your different recipients. But the main advantage of Cvitae is to allow you to use it as a job offer/application and contacts management tool. With its capture function, job offers found on the Internet can be directly saved into your contact list and then followed-up. Version 1.3.1 may include unspecified updates, enhancements, or bug fixes.
Download from CNET
Oct 30, 2012 | Computers & Internet
I want 2 use my computor 2 right a personal letter and ime no further on wen i am asking this simpel qwesion ime new on computors very new but instead ov getting a answer i am being asked a pay fof this...
use either word word-pad they are usually found behind the start button it will open up when you click on it don't forget to spell check usually a check mark looking thing and either press print or the left control button on keyboard and p on keyboard it should then print your letter
most public libraries offer beginners classes
and you can always access help in any program by hitting the f-1 key at the top of your keyboard
my 70 year old mother and 90 +year old grandmother took the classes because they had no idea then at most of what i was saying and now they are as proficient as anyone
good luck and please vote
Nov 30, 2010 | Computers & Internet
What does the insert key do?
Press and the text you type will over write what ever you have on the screen. This is typically used in most applications to "type over" existing text without moving the other letters/numbers/characters around.
This is my example of how the insert key works.
hit the insert key and position your cursor at the "w" in works.
Now type WOW!!.
You should now have:
This is my example of how the insert key WOW!!.
Clever these programmers. :)
Keep in mind it depends on the application you are running also.
Have fun!
Oct 03, 2009 | Logitech Cordless Desktop EX110...
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
Prints out letters too small to read.
this is a very general question, since each program may have a slightly different varition of how to set the font size.  fortunately, most third party vendors set the font in their programs, the same way microsoft does in theirs.  for everything prior to Vista with word 2007, you would click on file and then select printer settings.  this sets the base font and other default printing features.  also, microsoft uses styles in some of its office products, like word for instance.  styles are likea template whch follows the same pattern for font; type face, and other enhancements like bold and italics.  if you get stuck and need more help, you can always click on help for the application you are using and type "set font" as a search string to find how to set font size for the program you are using.  basically printers do what the program tells them to do and by that i mean print letters and words in the style and font size you previosly have set.  if the letters are small, it is because the program is set to print small.  you need to set the font for every application you use.  if you want help with a specific application, please let me know what that is and i will be able to give you a more specific answer.
good luck....
May 18, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Computers & Internet Logo
55 people viewed this question
Top The Computers & Internet Experts
Darren  Means
Darren Means
d3yavu3
kimblebear
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
