Question about Janome Sewing Machines
Janome DC4030position of the needle is not fixed moves easy left or right with the fabric when sewing but does not respond by touching button to change the position of the needle how can it be fixed?
bargainbox
  • 1388 Answers
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Posted on Feb 16, 2008
bargainbox
  • 1388 Answers
SOURCE: touch screen not responsive
You need to re-align the touch screen using the following routine:
Accessing Alignment Mode:
Then you will see a text message something like
"Press + to align"
STOP
Don't touch the "+" in the text message !!!!!
The one you want will be elsewhere on the screen and all on it's own, with no text around it.
Using the non pointed end of a needle, or the spare spool pin (nothing sharp) gently but as accurately as you can, touch the centre of the +
The + will move to several more locations as it organises the height, width and orientation you give by touching the centre of the + as it appears each time.
When it is finished, turn machine off, then on as normal.
If this does not correct the issue, it may well be something else, so please, if you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 18, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Trying to sew a buttonhole
You can get all the info of alignments and features of your machine here:
Manual of your machine:
http://www.sewingmanuals.net/bernina-910-sewing-machine-service-man.html
https://www.sew4less.com/product/140/Bernina_910_Instruction_Manual
http://sewingwishlist.com/bernina.html
This information is available online but not for free.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
SOURCE: Janome Memory Craft 7000 Sewing
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
Posted on Jan 18, 2009
  • 98 Answers
SOURCE: needle doesn't move
the problem is some fabric, dust or thread is stuck behide the plate that holds the sewing needle and foot.
Posted on Mar 10, 2009
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
How do I set the tension on my JANOME 3434D serger?
Begin by setting all 4 dials on "3" which is the default setting on this model (often "5" on other machines). If a beginner, it would be best to thread the machine with four different colour threads according to the colours indicated on the tension dials (yellow, red, blue &green) so that it is easier to see how each thread responds as you adjust the dials. The two lower dials are for the loopers & must be adjusted until the upper & lower loops meet on the cut edge of the fabric - if below the edge: tighten the left dial & loosen the right dial (& visa-versa) just a fraction at a time. The two upper tension dials are for the needles: if too loose, loops form underneath the fabric below each needle, & if too tight the lower threads will show through to the upper side of your fabric where it is pierced by the needle. Good luck!
Jan 18, 2015 | Janome Sewing Machines
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
I have a Janome sewing machine and I have forgotten how to move the needle so I can sew to the right... how do I move it ??
Press the Adjust key at the bottom of your screen. Press the plus key to move your needle to the right and the minus key to move your needle to the left. Use the first + and - keys that shows the needle.
Oct 19, 2009 | Janome Sewing Machines
Pulling fabric
Buy new needles! Buy size 10 or 11 Microtex Sharp needles. If this solves the problem, Great! If not,move the needle to the left needle position. This gives it more support and less possibilities of doing what it's doing.
sewman7
Oct 28, 2008 | Janome 2049LX Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Juki MB-373 Button Attaching Machine
Use a thicker needle.
Release the looper screw and move it back and close to the needle, but without touching.
Tight the looper screw.
Adjust the needle through (left and right) wider.
Jun 07, 2008 | Sewing Machines
Fabric doesn't Feed
I have a Janome, and when switching from embroidery back to sewing, I must touch a button that electronically moves the mode from embroidery to sewing. In some cases, I've also had to turn off the machine for a few minutes and then turn it on again.
I used to own a Viking - it had a little door covering the attachment link for the embroidery arm. If it wasn't perfectly shut, the machine wouldn't convert to sewing mode, regardless of what button I pushed.
Nov 19, 2006 | Bernina Activa 130
Sewing Machines Logo
24 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
