Question about Labtec 961307-0914 Webcam
Yahoo messenger to cam
  • 556 Answers
Re: yahoo messenger to cam
0 characters
3 Points
If I will be using my web cam I have this error message. Error 502 - Bad Request The server could not resolve your request for uri:...
There's no problem with your webcam.Its the yahoo messenger error. I recommend you reinstall the yahoo messenger and reconfigure the webcam to yahoo messenger. By the way your error is an application error online when yahoo messenger cannot process your request online because of a broken server/heavy traffic via internet.
Feb 01, 2011 | A4tech PK-635 Webcam
I m connected yahoo messenger while i m open cam that time give a massege 'a network error occurred while connection to the server '
This type of issue is usually solved by reinstalling the particular software which is giving the network error.
Please reinstall the yahoo messenger and let me know if you still face the same problem or not.
Thank you for using fixya.
Nov 17, 2009 | Labtec 961307-0914 Webcam
Problem on cam
I used to get this when I was on dial-up but never since going broadband - so the bandwidth may be fragile.
You need to interrogate what is happening when the webcam is transmitting by opening the webcam menu on the webcam frame and click "statistics" Its best to transmit the "small" image and use the zoom 200% when established ( same as sending large photos by email ) - if I go for speed rather than quality on the slider I can achieve 5-6 frames per second ( small size) but I normally transmit about 1-2 f/s.
I have my webcam under VFW (video for windows) control as I used to get freeze problems. This involves a registry change - detailed in Messenger help
You can tell when its under VFW control because VFW will be on the bottom of the Statistics box. You may need a little bit of software to make it work, if like me you do not have Directx on your pc - if so download the software featured here.
Dont worry about using the proxy server in "Connections" - Use it when you have to - I had to use it today to make my my webcam work - I also had to increase my virtual memory but that was as a result of error messages
Aug 12, 2009 | Labtec 961307-0914 Webcam
Logitech Webcam problem connecting to a server
Temporarily disable your firewall. Does it connect then?
May 14, 2009 | Logitech QuickCam Pro 4000 Webcam
Yahoo instant messenger shuts down everytime I try to use web cam
The camera may not be compatible with Yahoo, Try a different service to use the cam on? if that to crashes then its something with the drivers.
Nov 25, 2008 | Microsoft LifeCam VX-6000 Webcam
A network error occurred while connecting to server
See section B. Yahoo Messenger in info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype ( ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger ( ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Nov 15, 2008 | Labtec 961307-0914 Webcam
Error message connecting web cam on yahoo messenger
make sure that the web cam attached to the personal computer nor
in remote computer . if it attached to the remote computer it may have permission problems.
Dec 13, 2007 | Logitech Webcam
Cam images
hi it is not possible to send or recieve images using webcam,only you can video chat with your webcam
yahoo messenger definitely allows webcam chat .
the user with whom you are chatting must have webcam if you wanna see that person on your screen........!
Nov 21, 2007 | Logitech QuickCam Messenger Web Camera
Webcam connecting to server error
there as bin sever problems with yahoo this wont be down to the cam keep tryin the cam an yahoo should sort it out in tym
Nov 17, 2007 | GE EasyCam Plus Webcam
Server error on Yahoo when connecting
Check your firewall many are having this same issue especially with Norton
Oct 22, 2007 | GE EasyCam Plus Webcam
Labtec 961307-0914 Webcam Logo
124 people viewed this question
Top Labtec Webcams Experts
micky dee
Shahzad  Waseem...
Shahzad Waseem...
Robin Hill
Robin Hill
Are you a Labtec Webcam Expert? Answer questions, earn points and help others
