Question about Water Heaters
Have the threshold 4 cube organize shelf 13 inch , and need one replacement shelf and pegs, in natural color, do you have resource I need to contact?
2 Suggested Answers
  • 77947 Answers
SOURCE: Something found in nature that is needed for humans called is it called natural resources
Yes things taken from the natural world for mans use are referred to as natural resources.
Posted on Dec 20, 2016
anything that you can pick off a tree, get out of the sea, dig up from the ground or get from the air is called natural resources
you have to be a lot more specific if you want a better answer so write more details in your next post as posts are not linked
Dec 20, 2016 | Water Heaters
How to repair code 13 for tankless water heater
Code 13 is probably Rheem, Richmond, Ruud, Paloma etc tankless.
Copy following link for troubleshoot resources:
Error 13 is oxygen depletion sensor
Imperfect combustion.
For example if tankless does not have required maintenance, then burner can get dirty and clogged.
This will cause unburned natural gas to rise inside hot flue pipe causing risk of explosion and fire, or in case of propane gas that is heavier than air, the gas will build up inside combustion chamber and cause explosion and fire.
Oct 15, 2012 | Water Heaters
Error code c4 13
C4 13 is probably PC board failure.
Call Rheem and they will send new PC board.
Or it could be sensor failure, or other cause, but generally PC board.
Imagine if your computer needed a new motherboard. Same with replacing tankless PC board. You would expect your computer to have more problems soon.
Copy following link for Rheem troubleshoot resources:
Sep 26, 2012 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
I have a paloma tankless water heater, ptg-42pvn. It was flashing, C4, 13 and now it only flashes -0, 13 and will not even turn on. Tried to reset it by unplugging it and it only flashes -0, 13 even...
Multiple error codes can mean different things, including bad PC board.
C2 13 might be the oxygen sensor. -0 and no operation indicates bad board, but other things might be notched into same problem like loose connections.
Error codes are starting point for troubleshooting.
Before calling service technician, open following link for Rheem-Paloma troubleshoot resources including Rheem chat.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Code c7 13 is displayed on control panel. When I reset it it runs for a few minutes then quits again
Open following link for Rheem troubleshooting resources:
C7 is communication with remote control, but can also be related to other problems.
For possible C7 quick fix:
Apr 21, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
C7 13 error code on my tankless
Internet doesn't have clear-cut solution for C7 13 error code.
If concise repair information or service bulletin comes available, I will update this thread.
Open following links for Rheem troubleshooting resources:
Apr 16, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
RTG 74-PVN-2 Rheem tankless water heater. Works fine for a month or so at a time, then I get C2 - 13 error code. Did I hear this model was recalled?
Before calling service technician, open following link for Rheem troubleshoot resources including error codes and typical manuals.
Recall website:
Error code C2 13 call Rheem.
Read manual cover-to-cover to make sure your tankless water heater receives yearly maintenance required for unit to continue working.
Tankless are maintenance heavy which can quickly eliminate any promised energy savings unless you de-lime and troubleshoot and read tips-and-tricks others have written and glean information from service technician who visits your house. Mostly glean how much tankless repairs and parts cost vrs buying whole new tank-type gas water heater at local box store, since all costs are energy.
Feb 16, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Heater shuts down with C4-13 code
your not getting enough fresh air to it. where is it located? you need 1 square inch per 1000 btu's. it's having irregular combusion.
Aug 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Water Heaters Logo
35 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
