Question about Power Computers & Internet
How to open a Sennheiser DSP 360 Dolby Surround Processor?
The only button that works is the power button
techman
  • 3130 Answers
SOURCE: Center, surround speakers not working. "Can't Use" message for DSP.
Sounds like the old stuck button thing after a move??? What i mean it go over all the push buttons and maybe you will find one that is not pushing in and returning??? If alls ok then you should check the obvious like bent shafts or balance controls ect. ay have jogged something inside and you will need to see a pro to assit you unless you know how to trouble shoot solid state electronics?? These units have no real serviceable parts inside. Check with your owners manual for the sevicer nearest you. If they are not listed call the service # or try 1-800-289-AIWA . good luck
Posted on Jun 06, 2006
hogan doan
  • 227 Answers
SOURCE: Pioneer 5.1 dolby surround multichannel processor ?s
You will need extra amp(s) to run 5.1 surround sound using out IP-Bus at the brain to in IP-Bus at the processor and rca output to the multi channels amp(s) and control the surround mode which is automatically activate by the format of the disc. The IP-Bus cables is colored polarized at each end to inter connect all components. Just hook them in series follow the color you may add all the components you have. You can also down load wiring diagrams at pioneerelectronics.com. Goodluck.
Posted on Apr 26, 2008
SOURCE: RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Posted on Dec 28, 2008
SOURCE: Samsung HT-C550 The DSP/EQ or the Dolby Pro Logic
I had the problem and after pressing the DVD Receiver\DVD button to no avail went back to setup and turned the ASC Setting to off. Apparently I had forgotten to turn it off after doing the Auto Calibration.
Hope this helps.
Posted on Dec 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi, I have a Yamaha DSP-Z9 amp. The amp runs
Hissing or high-level digital hash noise? Undecoded DTS or data bitstreams produce very loud 'rush' sound when treated as analog sources. Is it all sources or just some?
http://www.retrevo.com/support/Yamaha-DSP-Z9-Amps-manual/id/1071dj786/t/2/
As far as service manuals go, web search it "Yamaha DSP-Z9 service manual" - many for sale.
http://www.ebay.com/itm/Service-Manual-YAMAHA-HTR-5740-DSP-Z9-YST-SW1500-/130526188617
http://srvman.com/9131h1-d2pz9-rmrvicm-28u58l-p-1010.html
Posted on Sep 11, 2011
Testimonial: "Thanks for the speedy response. This problem occurs with all sources and the noise is similar to fm noise. Thank you once again "
Let me clarify whats happening here. When I put it in Surround mode, or DSP mode, the buttons do light up, but there is no sound. If I push the Analog Direct button it does light up as well and it does...
With no specific model mentioned it's hard to look in a manual for recommendations or visualize what possible switch may be out of place.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jul 12, 2011 | JVC Audio Players & Recorders
I want to record an MP3 CD, or a Music CD and be able to hear it with the Surround Speakers, not just Left and Right, for some reason whenever y insert a music CD the only speakers that i hear are the Left...
Press the surround button and change the surround mode to Dolby Prologic Music or Movies.Since there are only 2 channels in your MP3 disc and music cd the systems default setting is stereo.
Use your DSP ( Digital Sound Processing ) function to create 5.1 from 2 channel source.
Mar 14, 2011 | Audio Players & Recorders
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
Problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Mar 01, 2009 | Denon AVR-2106 Receiver
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
Apr 16, 2008 | Pioneer AVIC-N2 Car DVD Player
Dec 18, 2007 | RCA RT2280 System
Jun 06, 2006 | Aiwa AV-D50 Receiver
Computers & Internet Logo
50 people viewed this question
Top Power Computers & Internet Experts
john smith
Sattech
Level 1 Expert
MonsterByte
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
