Question about Raymarine RL70CRC GPS Receiver
SL70RC SCANNER IS WORKING NO IMAGES ON DISPLY SCREEEN
I CHECKED FOR ANY SIGNS OF ELECTRICAL SURGE. NONE APPARENT.ANY IDEAS .UNIT LOOKS CLEAN??
  • 43 Answers
Look if your Radarcable i ok (broken oxidation)
Be sure that your Powersupply is ok
Try your SL 70 on a nother boat if if works
your Scanner has a failure in the Outputboard
Posted on Oct 22, 2009
Why is it surging under load?
Yep - the carb needs to be removed and cleaned out thoroughly to remove the clogging responsible for the surging. Motor needs a smooth supply of gas - look at what your car does when you jerk around with the gas pedal. Also check the governor area of generator since that keeps motor running at a certain fixed speed. If there is something wrong with it, that will also cause the problemo.
Sep 08, 2015 | Generac XG8000E - 8000 Watt Electric Start...
How do i fix my toshiba studio 202s,double image result
If you have replaced all that, check your drum cleaning blade and your erase lamps, these two items will contribute for Ghost images "double image". The erase lamps disperse the electrical charge so the blade can scrap the toner off the drum.
Dec 10, 2014 | Toshiba Office Equipment & Supplies
SCANNER DOESNT SCAN ALL OF THE IMAGE
If the scanner is connect to Surge protector, try connecting the scanner to wall outlet. Also turn off the scanner and Clean the Scanner glass with lint free cloth
Regards,
Seans
Feb 26, 2013 | HP LaserJet 3055 All-In-One Printer
There are some white spots on the screen of the t.v. inside whenever the t.v is turned on another one comes on the television screen is almost full now i can hardly see the screen
This is a DLP type TV. Is it in a dusty environment. Could there be dust and dirt on the projector or inside the disply screen.
Also it could be the imaging unit having pixel failure.
Check first for a clean image path, including the internal mirror, if this doesn't help then it may be the image unit.
Mar 25, 2011 | Samsung HL-S5086W 50" HDTV
I have 2 Epson V500 Scanners, 1 of them I just have on standby. The one I use daily does not turn on. I tried using the cables of the standby unit already. I checked the fuses on the plugs of both...
  1. Check that the power socket switch is on Make sure your scanner's power cord is securely connected to the scanner and a working electrical outlet.
  2. If your scanner is supplied with a power adapter, make sure your scanner's AC adapter is securely connected to the scanner and a working electrical outlet.
  3. Make sure that the power outlet works. (If necessary, test it by plugging in another electrical device and turning it on.)
  4. Check that the power switch is on at the mains socket. If this is on, carefully check the power cable to ensure it is not damaged and remove then reseat it before attempting to turn the scanner on again. If your scanner has a power button, make sure that the button is depressed so it is turned on. Also, make sure that your outlet works and is not controlled by a wall switch or timer.
  5. Power off the scanner at the mains socket. Unplug the power cable from the socket, then remove and reseat the power cable from the scanner's power cable port. Plug the scanner back in at the mains and ensure the socket is switched on.
  6. If your scanner has a power button, does the power button depress when pressed? Press down firmly on the power button, if it is stiff and does not depress then there may be a problem with the button.
  7. Connect the scanner directly to the mains - not via a surge protector or extension lead. If your unit is connected via a surge protector or a power strip/extension lead, connect the unit directly to the mains socket.
  8. Try another suitable power cable. Check that other electronic devices connected to same power socket have power and try another mains socket and another power cable if necessary. Failing this try another suitable and known-working power cable. Depending on your scanner, a standard "kettle lead" or "figure of eight" power cable is used. If there is power to the scanner (indicated by an illuminated Start light), when a different power cable is used, then the fault is with the original power cable.
If the unit does not power on after following the checks above, contact Epson for support. If your scanner uses an AC adapter, then this may need to be replaced. If your scanner is over 12 months old, you can purchase a replacement AC adapter directly from Epson.
Nov 13, 2010 | Epson Perfection V500 Flatbed Scanner
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
The image has patchy lines
The scan image you have above could be caused by a few different issues but the number one is a power issue. Make sure that the printer is plugged in directly to the wall and not into a surge protector or a power strip. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a copy. Does the image look any better?
If this does not solve the issue then it may be that your scanner bulb is going and therefore not illuminating the image properly. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
Feb 16, 2008 | HP ScanJet 2400 Flatbed Scanner
No indication on display module - apparant loss of power
Did you check the power cord.
Connection(s) could have been fried during power surge.
Dec 27, 2007 | Ovens
Raymarine RL70CRC GPS Receiver Logo
168 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
