Question about Danby Refrigerators
I have a mini danby refrigerator the door will not shut tight therefore the rerri will not getb cold
    Top Expert:
  • Danby Master
  • 50,411 Answers
Try taking the stuff out then trying it .
Posted on Oct 06, 2017
  • 489 Answers
SOURCE: LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Posted on Jun 08, 2008
barkencoa
  • 3463 Answers
SOURCE: The upper oven door dosen't shut tight.
Door not closing properly is normally due to weak door hinges.
Normal procedure is to replace both the hinges.
Plz rate my solution.
Thanks.
Posted on Jan 09, 2009
  • 508 Answers
SOURCE: Refrigerator side by side cold but not cold
weak evaporator fan!!! :)
Posted on Jul 08, 2009
Number5Gayle
  • 98 Answers
SOURCE: refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Posted on Aug 09, 2009
  • 109 Answers
SOURCE: freezer door does not seal tightly and will open
Change the magnetic gasket from a good service center or you can change it yourself. Thanks.
Posted on Sep 29, 2009
I have a mini refrigerator and it just stopped getting cold it is a danby would it be worth repairing
Nope, unless you are ready to pay more to repair than getting a new one!
Mar 03, 2017 | Danby Refrigerators
My danby bar fridge doesnt shut off gets too cold
Check to see if you accidentally reset the cold setting when jamming stuff in the freezer. Check to see if the seal around your refrigerator is pliable and sealing correctly. Vacuum and dust the condenser coil to clean the coils periodically since that is a VERY common problem. A brush works good for that and you usually find the condenser coil under or near the back of the refrigerator. Check to see if any ice is on any outside lines which would indicate a freon leak. Suspect the circulating fan if the first don't work. A thermostat can also go bad.
Mar 03, 2015 | Danby Refrigerators
Motor seems to be running almost constantly. Food is cold and freezer is working. Only shuts off for a short time and comes back on again.
avoid frequently opening of door. check door gasket close tightly. adjust setting of thermostat to coldest setting
Jan 25, 2011 | Hotpoint HTS16HBR Top Freezer Refrigerator
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
Refrigerator door doesn't seem to be sealing shut...seem to not be closing and therefore running all the time
The door has a magnetic lining which keeps the door tightly shut at all times. Over time this lining can decay (magnetic strenght). I would advise you get it replaced & its not too expensive either.
Dec 02, 2010 | Viking Professional VCBB363SS Stainless...
Broken freezer door hinge on Danby Model # D9600WY
hello. here is the link to Danby customer service. They can assist you.
http://www.danby.com/customer_service
Aug 14, 2009 | Danby (DAR604BLS) Refrigerator
Brand new wont get cold
I have a Danby Premiere Mini Fridge. It was sitting in the garage for a while.
I plugged it in and nothing, no sound .. no cooling.
The outlet is definately on. Do I have to push any buttons or reset something?
Thanks for your help.
Mario
Jul 06, 2009 | Danby (DAR604BLS) Refrigerator
Danby propane frig model DPR2260-2 owner's manual
I have the same refrigerator and am looking for the manual as well. Did you ever find one? If so, where?
Thanks,
Ari
Renata BC
hi_ari@yahoo.com
Oct 06, 2008 | Refrigerators
Refrigerator freezes contents
Get a new cold control for it
Sep 01, 2007 | Refrigerators
Refrigerators Logo
89 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
