Question about American Range AF45LP Deep Fryer
American range af45 pilot goes out when t-stat is set
Installed new thermopile worked good for 3 weeks then problem reoccurred. Can get pilot to light but when setting tstat the pilot goes out. Did get it to fire once and come up to temp but failed relight for tstat cycle off-on. checked all connections.
  • 4 more comments
  • rickyturner1 Jul 25, 2009
    gas
    gas
    Well dickson948 I might understand a little more than you think I am a refrigeration and a/c tech I have not done any gas in 15 years or so . How about I set the gas pressure at 4" of water column and clean out the vent. Why did you even respond if you are going to be so arrogant and then end with a god bless?
    dickson948 I am a a/c and refrigeration tech I have not done any gas in many years but I am capable of grasping the info if you really do have the knowledge.
    How about I set it at 4" of water column and clean out the vent.Please dont respond anymore unless you can help you sound a little arrogant. God bless
  • rickyturner1 Jul 27, 2009
    Thank You Sir! Now I understand. Thank you for your sharing your knowledge and yes there is another pressure regulator on the line. I think I can fix it now. I apologize for stressing out. Its easy on the computer.
    You have a nice day.
  • Ned C Cook
    Ned C Cook May 11, 2010
    gas or electric?
    President:
  • 3,433 Answers
Sounds like Dickson is an unemployed "gas fitter".
I would suspect a faulty thermocoupler. Your reference to a thermopile threw me off, Thats why I wonder if it was gas or elwctric. Yeah, consider the thermocoupler. I've haven't a clue what dickson was talking about and in all honesty you would be a better judge about making any sdjustments. Good luck
Posted on Jul 25, 2009
    Scholar:
  • 86 Answers
Sorry to say this, you should not play around with gas equipment, please call in a gas fitter to deal with it. I know what is happening and if I tell you it is the gas pressure problem you still don't understand what I'm talking about or how to clean out the pressure vent hole or how to check the gas pressure because you don't have the proper equipment. Please let the right people do the right job. God Bless.
  • Dickson LAU Jul 27, 2009
    First of all please accept my sincere apologize , I only want to tell people don't play around with gas equipment because they are not like electricity they will cause explosion , I've my eyelash and my hair scored before, even I'm a gas fitter.
    I didn't know I'm talking to a pro. Now let us get down to your problem about the pilot going out while you turning the thermostat to call for the main gas to open. The 4" gas full pressure will rush to the main burner and the pilot burner .and that is what it suppose to be.
    But the problem you have now is when the main valve open it draws most of the gas and the pressure drops so much that it can't keep the thermopile produce the normal flame to keep the pilot on and sometimes the pilot have no gas it just goes out like the problem you 've now ,shutting off in the safety condition. ( You can see it happening while you turning the thermostat and watch the pilot flame going down ,immediately turn the thermostat off the pilot flame will comes up strong again)
    Another question is. Is there another pressure regulator at the inlet of this deep fryer , there shouldn't be one . because the combination valve already have a pressure regulator build in. Except the inlet gas line is in High Pressure.
    Now the vent I'm talking about is on this combination valve ,( they call this the regulator vent ) it is only a screw but have a very small hole vent if this is block the gas pressure will not be release and you'll have your present situation. Sometimes when you take off this screw the unit will work properly then you know the problem is in this regulator vent screw. You have to clean it out and put it back thought.
    I hope this will help. Sorry again that I made you fill uneasy. Let us exchange our knowledges instead.
    Have a nice day, God Bless again.
Need some help. I rebuilt my old wall heater and it won't turn on. New thermopile, pilot and gas valve. The pilot works, but burner won't ignite. New thermostat too.
turn thermostat to off position check wires from thermopile to stat and gas valve for damage etc . Thermopile has to warm up and make 600 mille volts to work . Try this then open stat and see if it fires up .
Dec 05, 2016 | Heating & Cooling
I have an arr3140ss American gas range. Just recently installed new burner and igniter.Roasted and baked all last week no problem todayI turned on the overn abd got up to 550 for pizza. put pizza in
Sometimes the pilot light goes out on this type of oven. This could be caused by a draft, or sudden jolt. Even if the top burner is working, the bottom won't go on until the pilot is lit. Check your manufacturers' instructions for locating and re-lighting the pilot.
Best of luck.
Nov 30, 2014 | Kitchen Ranges
I have an American Range fryer with a thermopile, the pilot will stay lite until the burner comes on then it seems to blow the pilot light out, not every time either....any ideas?
The pilot light has only a small orifice and this can carbon shut with time; with a small wire, you can try cleaning it.
They may also provide a separate adjustable valve for the pilot and this setting may have drifted over time, shrinking the flame height and therefore resistance to being extinguished.
Sep 19, 2014 | American Range Kitchen Appliances - Others
Fryer cut off but pilot stays on
You could have a weak pilot or thermopile. If the thermopile is not heated correctly by the pilot, it cannot generate enough millivolts to open the gas valve. The same is true if the thermopile is faulty. Thermopiles consist of several junctions of which only some may go bad causing low millivolt output. Millivolt output with the thermostat off and pilot lit should be around 600 millivolt, you can check with a DC multimeter set on MV across the two wires coming from the thermopile. Remember, the thermopile has to be heated by the pilot thoroughly before you will get the full millivolt reading and the thermostat must be off. Cleaning the pilot assembly is often helpful, thermopiles are inexpensive and relatively easy to change. Of course, other problems can cause this issue as well, but the above are most common.
Mar 28, 2014 | Imperial Kitchen Appliances - Others
What is the problem when millivolt gas valve can not keep it pilot on?
Hi there.
Probably the thermopile is not receiving enough heat from the pilot flame to generate 500 to 750 millivolt to hold pilot flame. The thermopile may have soot or dirt on it so try to clean or the pilot flame itself does not give enough heat, try adjusting pilot flame. Or the thermopile could not generate the right amount of millivolt even if it is clean and receiving enough heat from pilot flame, so better replace the thermopile.
Check also the hi limit, it must have continuity across its terminal.
Regards
Sep 20, 2011 | American Range AF-25 Deep Fryer
I have the AF45 fryer. I cannot light the pilot on this fryer. I have tried all possible solutions to this but still wont work.
Normally, on manual gas fryers, people don't hold down the light pilot button long enough for the sensors to heat up, to tell the pilot to light.... That's our number one complaint, and number one service call, and it's almost always the same thing;..... Hold the button down much longer, then try to light it... If you still have trouble, call our service tech, Ray @ 888-542-5959, at Restaurant Equipment Outlet, Cincinnati, Ohio. Thanks, Susan REO
Jul 16, 2011 | American Range AF45LP Deep Fryer
Pilot light will light but wen i turn to on position it does nothing
Make sure that the pilot flame is sufficient to heat up the thermopile and also make sure that the thermopile is free from dirt or soot.
Jun 03, 2011 | American Range AF45LP Deep Fryer
Trying to light the pilot light on deep fryer when i push button in it lights but when i let go of button pilot light goes out what am i doing wrong
If the pilot flame does not hold after releasing the button for at least 20 to 30 seconds, try to clean the thermopile and tighten all wiring connection on gas valve, thermostat and hi limit the repeat the process. The thermopile must be heated by pilot flame in order for it to generate small amount of voltage to open the pilot valve.
If this does not correct the problem, try replacing the thermopile.
May 24, 2011 | American Range AF45LP Deep Fryer
My fryer wont lit up the fire.only the pilot works
Check if there is sufficient gas supply as stated on the unit's nameplate. Check if there is no soot/ carbon build up on the thermopile for this will lessen the heat from pilot thus reducing milli volt it will generate to open the main valve, in short, main burner will not fire up if there is soot/ carbon on thermopile. Check and tighten also all of wiring connections.Check if the thermostat is set at higher temperature. If all of these did not correct the problem, try replacing the thermopile.
May 14, 2011 | American Range AF-25 Deep Fryer
American Range AF45LP Deep Fryer Logo
624 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
