Wash tank not filling with water - Washing Machines
2 Suggested Answers
SOURCE: washing machine will not stop filling water
you need a washingmachine doctor home NOW
KOLBRUN
Posted on Feb 25, 2012
It does not heat water. Light comes on, but water does not heat up to temperature. Help!
Either your heater or your control are bad. Testing the heater circuit for continuity will give you the answer. If you don’t know how to do that I would suggest not doing it yourself.
Feb 11, 2018 | Dishwashers
GE WASHER STOPS DURING WATER FILL WASH AND RINSE LIGHTS LIT.
there is a small plastic tube that runs from the washer tank up to a pressure switch to let it know tank is filled and to start washing. As water fills it creates increasing air pressure in that tubing. If the tube is clogged at bottom end or is leaking ANYWHERE that pressure bleeds off. Those switches are also adjustable via a small set screw on the switch. Is problem affected by load size? If tube leaks usually it may overfill and NOT shut water fill off. Likely the switch is bad, but inspect that line thoroughly.
Oct 26, 2017 | GE Washing Machines
My Samsung washing machine wont stop with water filling
First clean the detergent drawer and button trap, then make sure the siphon cap {it might say "MAX" on it) is installed properly. Make sure water pressure is not too high.
Apr 18, 2016 | Samsung Washing Machines
Why doesn't my water softener have water in it.
The tank is not *filled* with water - it is filled with salt. There is some water in the tank - as long as you are using salt, the brine tank is working. Have a look at this video below:
Jun 10, 2015 | Washing Machines
Washing machine will not stop filling water
KOLBRUN
Feb 25, 2012 | Kenmore Washing Machines
Do you put water in the big compartment under the solution compartment when wet washing your floor
You put water and Hoover Cleaning Solution into the top tank. Push down on the release button at the top of the tank just below and in front of the handle. The cap is also your measuring cup. Fill it with the Hoover Cleaner Concentrate. Pour that into the tank and fill it to the fill line with warm water.
The dirty water will be extracted into the bottom tank.
May 20, 2010 | Hoover H3030 FloorMate SpinScrub 500...
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
