Question about Roku Televison & Video
Reactivating roku 2...I have tried everything..won't work
My roku remote will not work I put fresh batteries in also
Unplug power to Roku for 20 seconds. Remove batteries from remote then plug in roku and install batteries when Roku name is dancing this should work.
May 29, 2017 | Roku Televison & Video
My hdmi input 2 gets a no signal blue screen. My Roku is hooked up to this port. have replaced hdmi cables and even got a new roku.
Sounds like you have done everything correctly and have covered all the angles.
Set Up and Troubleshooting is here. If nothing in that, contact them direct as the unit might be faulty. You did have verified power to the unit?
https://support.roku.com/hc/en-ca/articles/208754878-Roku-3-Model-4230-Setup-Instructions
https://support.roku.com/hc/en-ca/categories/200889378-Setting-Up-Your-Roku
Setting Up Your Roku Roku Support
Mar 18, 2016 | Polaroid Televison & Video
Channels for roku are displayed but cannot control them remote is frozen
YouTube update: Channel now available to all current ...
https://blog.roku.com/.../youtube-update-channel-now-availab...
Roku, Inc.Apr 22, 2014 - It's not got all of the new channels, but its still got everything I originally... I bought in 2011 has a broken charger cable and the no longer make them. .... i can'tsee my youtube playlists on roku tv .... just subscriptions, ... In Linux, I use a Roku remote controller script written in Bash to control my Roku XS, and ...
Roku Forums • View topic - New Roku 3, Remote not pairing
forums.roku.com/viewtopic.php?t=57520
Jun 14, 2013 - 15 posts - ‎11 authors
Just received my new Roku 3, well about 2 hours ago, and still can't get the remote to pair. ... I have changed the wifi channel 9, who knows, but I tried that. ... flash, theRoku device then displays a remote with a wifi signal icon and .... trouble-shooting steps again, even though you've done them ... they need ...Missing: motorola
Roku Remotes Information & Troubleshooting - Roku Support
Jan 01, 2016 | Motorola Mobility ROKR E6 Smartphone
Why doesn,t my roku accept my win or pass key when i type it in
First, you may have to input the password for your Router. Which you can get from your service provider. Call them to make sure you have the right password. The Roku itself will give you a different password. This is why it is important to write everything down for your devices.
Feb 11, 2015 | Roku Televison & Video
My roku will not open any thing we were trying amazon got an internet error. Got right in computer
check your network from the computer, the roku should be listed as connected to the network map. If not, then your wifi or wired connection to your router is disconnected.
Jan 27, 2015 | Roku 3 Streaming Media Player - 4200R
Ive had a Roku installed I my living room for several years now without any problems. I recently purchased a new roku 2 for my bedroom and installed it everything works great on the new Roku 2 but the old...
Check the IP addresses of the units. They may have the same IP number. If they do assign each of the items in your network a static IP and it should work.
Jan 01, 2015 | Televison & Video
When I watch any channels on roku like GlennBeck, and Pandorda, I have been getting ERROR, please try again. Everything worked fine before. Its been like this for a week now.
Dec 01, 2014 | Roku 2 XD
Roku 2 remote won't work
If you have a Wi-Fi Roku remote or a bluetooth Roku Remote, the remote needs to be paired with the unit first before you can control the device. To pair the unit with the remote, you can do the following:
  1. Turn off the Roku player for 30 seconds by unplugging the power cord from the power outlet.
  2. Once you have the bouncing Roku on your TV screen, open the battery compartment of the remote and press the purple button there once.
  3. The Led on the remote should start blinking.
  4. Leave the Led blinking and don't press any button on your Roku remote.
  5. Wait for the Led to stop blinking.
  6. Once the Led stopped blinking, try to test any button and see if it works.
Mar 25, 2013 | Roku 2 XS Wireless Streaming Media Player
I AM TRYING TO INSTALL ROKU FROM MY PC TO A TV IN ANOTHER ROOM. I HAVE DONE EVERYTHING EXCEPT GET THE CODE IN THE ROKU ACCT. BUT CANNOT GET ROKU TO ACCEPT IT.
I need some info first.
1) Are you connecting by wireless connection to your roku device?
2) are you trying to input the roku code on their website, or are you trying to connect to a wireless access point with your device?
Oct 06, 2011 | Roku XD Streaming Player 1080P Wireless-N...
ROKU can't connect to local area network.
Have you got past the point where the Roku updates itself? If not, connect the Roku to the router via ethernet to get to that point. Make sure you can watch something on the Roku. Then try connecting wirelessly.
2. If you are still having trouble, connect the Roku directly to the modem. (this is temporary). If you can get the Roku to work, the problem is with your router and not the Roku.
3. Restore all the connections - it would be a good idea to reboot everything: Let the modem come back up, then the router, then the Roku.
4. Check for firmware updates for your router.
5. If you are still having trouble, post the make and model number of your router.
Feb 05, 2011 | Roku HD Player (N1100)
Televison & Video Logo
27 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
