Question about Lands Phones
How to set a time in euroset 2025 c - Lands Phones
How to set time on a Siemens Euroset phone 2025C
Try Googling (siemens)(2025C)(manual) without parens to get instructions.
Jun 15, 2017 | Siemens Lands Phones
How can I set a speed dial on SIEMENS: EUROSET 2015?
Lift the handset
Press the set key
Press the repertory key (under which speed dial button like to store)
Enter the number
Again press the set key
Mar 05, 2014 | Siemens Euroset 2015 Corded Phone
Euroset 2025c
Press Set followed by 3, enter the time now in 24HR format, and press Set again.
Nov 19, 2013 | Lands Phones
Does the Siemens Euroset 805 have a high low volume switch ?
Thanks M.Qasim for the solution!
Just a small correction you have to set the phone while is ringing. I did the following sequence call to the pone then press "Set" "#" "4" "#"
Oct 28, 2012 | Siemens Euroset 2005 Corded Phone
How to conference a call in a siemens euroset 2025c?
You need to change the Pause time from 3 second (Default) to 1 second. For this First of all your have to
1- press the "set" key on the Euroset-2025 set and
2- then dial 1020.(1020 for 1 second pause) (1021 for 3 second pause)
3- and "set" key again.
Now you can use the conference feature of set.
Jun 16, 2012 | Lands Phones
Euroset 2005 phone does not have high low volume switch
ya you are write the volume switch is not given in Euroset 2005. volume can be adjusted by this code while u pick up the receiver "Set/mute # 4 #"
M.Qasim
Jul 18, 2011 | Siemens Euroset 2005 Corded Phone
How do i change ringer tone and adjustment of Euroset 2005 Corded Phone
How to Change the ring tone of the Phone - "Siemens Euroset 2005"
1st - Lift the Telephone receiver
2nd - Press Set/Mute
3rd - Press # and any number 1 to 9 and then Press #
4th - Place the Telephone receiver in its normal Position.
That's it now you should have changed your ring tone of "Siemens Euroset 2005"
Thanks Enjoy
Jun 23, 2011 | Siemens Euroset 2005 Corded Phone
Can't get CLI to work on 5020
With the handpiece on the hook. Try typing #86 into the handset. This should turn on CLI from that handset.
Sep 13, 2009 | Siemens Euroset 5010 Corded Phone
Siemens euroset 4005. Cannot unlock phone
Man that's BAD! It's basically the phone problem...U can either change your phone or contact your phone service provider see if they can help u with the code.
Jun 02, 2009 | Siemens Euroset 2005 Corded Phone
Lands Phones Logo
180 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
