Question about Garmin Watches
My Garmin S2 Golf Watch has been working fine and for last week I either can't turn it on or it's not taking a charge the watch face remains blank?
SOURCE: I HAVE A MENS FOSSIL
Did you check the batteries. That watch has one battery for the time, and two for the logo display. After you put new batteries in you also will have to probibly short-curcit the battery, it will tell you if you have to on the back inside case. If this dosn't work send to the company, they have a really good warrenty. Good Luck!!!
Posted on Jul 07, 2008
SOURCE: Watch is blank/not charging
I have the same problem. I am not sure, but I think that, over time, the battery gets weak and dosen't hold its charge without exposing it to sunlight for an extended period of time. I think it may be time to change the battery.
Posted on Mar 08, 2009
escapement
  • 2334 Answers
SOURCE: E010 S95986 HSB power cell does not hold charge
Change the capacitor. This is the thing accumulating the energy. As the ordinary batteries, it may go bust, so, all you have to do is to replace it. There is no such a name as power cell in Citizen EcoDrive watches - there are CAPACITOR. Capacitor absorbs the energy from the light sensitive panel(s) and dispenses it in the ordinary battery manner. Advertisements are saying that you will never have to change the battery - that's right, because there are no batteries at all. Instead of battery there are CAPACITOR, but nobody says it will last forever. Rate me, plz.
Posted on Mar 05, 2010
Testimonial: "Thanks, that's what I expected. The manual says the watch has a manganese titanium rechargeable battery--I will get it checked."
  • 2501 Answers
SOURCE: my watch to my garmin forerunner 50 started
I have read the instructions for your watch and I found nothing in there that was helpful.
I am having a guess here but perhaps the memory is full (did you see the "Lo mem" warning?
Try downloading the memory to your computer if you can with a blank screen!
As a last resort, go to theri web site and find the "contact us " phone number and ask the maker.
Posted on Mar 15, 2010
e-Guru
  • 3917 Answers
SOURCE: Watch indicated "low battery" Jeweler
Hi
Try resetting it - it worked for me. First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
Rotate the tiny donut that clips over the battery so it touches the brass spring that is next to the battery, replace the back plate. you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electro mechanics of this watch.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 27, 2010
It died and won't charge or turn on
could be the battery .. try taking the back off,take battery out and leave the battery out for 10 minuets ..then put it back in . this could help restart the charging cycle . if not then you'll need a new battery
Apr 24, 2015 | Garmin Approach S3 Touchscreen Golf Watch
Can't locate sattelites on golf course
When you try to locate satellites it could take some minutes before the device find enough to calculate the location. Please give it some time. Also make sure the watch is charged.
Mar 16, 2015 | Garmin Approach S1 Wrist Watch green
When I plug in my s1 the watch just turns on instead of going to the charging screen. How do I get the charging screen?
I have had the same problem, but got round it by first powering off the watch, then waiting a minute or so. Then I attach the clip, having made sure I have the pins exactly aligned before I let them touch the contacts. Even so, a slight wriggle might be necessary to get them properly seated. I get it to work one time in three this way - what a daft bit of design!
Jul 30, 2013 | Garmin Approach S1 Golf GPS Watch
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 | Watches
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
Jan 04, 2011 | Garmin Forerunner 205 Gps Training Watch
My watch to my garmin forerunner 50 started bleeping last week and then it went blank (the watch), changed the battery twice but still not working. can you help?
Mar 15, 2010 | Garmin Forerunner 50
The watch has been working fine and suddenly will
I would recommend having the charger checked for good electrical flow and I would also have the rechargeable battery inside the watch checked. Even capacitors need to be replaced every so often because they just get wore out. Also, be sure that you arent exposing your charger or watch to extreme temperatures as this will cause problems.
If you have trouble finding a shop that can do this you can contact Garmin support directly at:
1-800-800-1020
or
garmin.com/support
Sep 19, 2009 | Garmin Forerunner 205 Gps Training Watch
The watch started working by itself.
Jan 18, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
61 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
