How do I set up new destinations? - Office Equipment & Supplies
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
How to set multiple destinations?
Some garmin satnavs allow you to save routes which have multiple destinations. The 265WT does not so the only way to set it for multiple destinations is to use via points. First press WHERE To and enter your last destination. Press GO and then while that is active pres MENU and WHERE TO again. Enter your second last destination and press GO. It will ask if you want this to be a new destination or a VIA point. Select VIA point. Continue to add other destinations in the same way with the destinations nearest to the end going in first and the closest to the start going last.
It's not ideal especially as it cannot be saved for future use but unfortunately for some strange reason Garmin do not include the option to store routes on all their satnavs.
Jun 11, 2011 | Garmin n?vi 265WT Car GPS Receiver
I have a HP C5580 printer and I can not scan to email. Do you have a solution for me Thanks Audrey
Step 1: Configure Windows Mail.
http://windowshelp.microsoft.com/Windows/en-US/help/00e419ef-fee2-472c-ad02-b14331571a521033.mspx
OR
http://www.apluskb.com/scripts/How_do_I_configure_Windows_answer3578.html
Step 2: Go to IE>Tools>Options>Programs>Email> Select Windows Mail
Step 3: Set Windows Mail as the default e-mail program
  1. Open Windows Mail by clicking the Start button, clicking All Programs, and then clicking Windows Mail.
  2. Click the Tools menu, and then click Options.
  3. Click Make Default next to This application is NOT the default Mail handler. If the Make Default button is not available, then Windows Mail is already set as your default e mail program.
Step 4: Populating E-mail program as scan to destination
  1. Open HP solution center.
  2. Click on Settings.
  3. Go to E-mail Settings.
  4. In the E-mail settings box, select the e-mail program to Windows mail and click apply.
Step 5: Change the Setting “Scan to” in Solution Center
  1. Open HP Solution Center, if it is not already open:
    • Windows VISTA: Click Windows Icon, click All Programs, point to HP, and then click HP Solution Center.
HP Solution Center opens in a new window.
  1. In HP Solution Center, click Settings, and then click Scan to...Setup. The Front Panel Destination List Setup window opens.
  2. From the Available Scan Destination list, click the program you want to be the scanning destination, and then click the Add button. The program moves to the Front Panel Destination list.
Note: You can also move the program to the top of the Front Panel Destination to scan to that destination automatically.
  1. If you do not want to change any other settings, click OK to close the Front Panel Destination List Setup window.
5. Check the functionality.
Feb 10, 2010 | HP Photosmart C5580 All-In-One InkJet...
I can't scan to computer to email letter
1.Open HP Solution Center, if it is not already open:
◦Windows XP or 2000: Click Start , click All Programs , point to HP , and then click HP Solution Center .
◦Windows Vista: Click the Windows icon, click All Programs , point to HP , and then click HP Solution Center .
2.In HP Solution Center, click Settings , and then click Scan to...Setup . The Front Panel Destination List Setup window opens.
3.From the Available Scan Destination list, click the program you want to be the scanning destination(Email), and then click the Add button. The program moves to the Front Panel Destination list.
NOTE: You can also move the program to the top of the Front Panel Destination to scan to that destination automatically.
4.If you do not want to change any other settings, click OK to close the Front Panel Destination List Setup window.
Aug 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
SCANNING ISSUE
You need to install the complete software from HP Website or use the link belows:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
After downloading and installing the complete software you need to set-up scanner.
Using steps and i m sure your issue will be resolved.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Jun 28, 2009 | HP LaserJet 3050 All-In-One Printer
Multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
Click Update .
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
All leds light on panel
Click Update .
Apr 27, 2009 | HP LaserJet 1300 Printer
I have a HP LaserJet 3055. I bought it when I was using XP but I now have a new computer using Vista. I have downloaded and installed from HP the installation setup program for Vista - followed all the...
As i understand that you u r able to print and copy fine which ensure that there is no issue with the connectivity and scanning device.
However next troubleshooting comes in picture is software as per you have mentioned that yoiu have downloaded and installed the complete software couple of times still the issue persists.
In that case we need to Programn Scan to option in the printer software and on your all in one.
HP LaserJet 3050, 3052, 3055, 3390 and 3392 AiO Printer series - How to Program the Scan To Button and Create New Destinations
Information
The Scan To button must be programmed before it can get used. However, some destinations are programmed by default if the all-in-one is directly connected to the computer.
Details
Click Update .
Dec 21, 2008 | HP LaserJet 3055 All-In-One Printer
Scanner will not save to computer
By default, the HP all-in-one sends all scans to the HP Photo & Imaging Gallery for you to preview. Suppose that you want to scan your photos directly to email instead. To do this you will need to modify the destination assigned to the front panel scan button. Here is how to do it:
  1. If you have not already done so, open the HP Director and click Settings , point to Scan Settings & Preferences , and click Scan to… Setup . The Button Settings dialog box appears, with the Destination List tab on top. The HP all-in-one automatically inventories your computer and lists all the possible scan destinations for you in the Available Scan Destinations list.
  2. Using our example of scanning directly to email, select the Email destination in the Front Panel Destination List and click the Move arrow to move it to the top of the listing.
  3. Click OK to save the new destination setting and close the dialog box. All of the scans you do using the HP all-in-one front panel buttons will now be sent directly to your email program, instead of to the HP Photo & Imaging Gallery.
  4. Click Scan Picture or Scan Document in the HP Director to scan using your new settings, or click a Scan button on the HP all-in-one front panel.
also
Setting a default scan profile Use the following steps to apply a scan profile to all future scans.
  1. If you have not already done so, open the HP Director and click Settings , and click Scan Settings and Preferences .
  2. Click one of the following, depending on the type of scan profile:
    • Scan Picture Settings
    • Scan Document Settings
    • Button Settings The corresponding dialog box appears. If you chose Scan Picture Settings or Scan Document Settings , the Scan Settings tab is on top. If you chose Button Settings , the Scan Button tab is on top. All of these tabs have the setting you need, Apply Scan Profile .
  3. On the Scan Settings or Scan Button tab, click Apply Scan Profile and select the scan profile that you want.
  4. Click OK . The scan profile that you selected will apply to all future scans for the scan type that you selected.
Apr 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
22 people viewed this question
jasbo
jasbo
