Question about Refrigerators
How long to get cool after plug in? - Refrigerators
  • 864 Answers
The compressor should start soon after the refrigerator is plugged in. (Make sure the control knob inside or the control panel outside is set for a low temperature.) You may not notice any cooling for a couple of hours and it could take 12 to 24 hours for food in the freezer to freeze solid and for ice cubes to be made.
Posted on Jul 25, 2009
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Why won,t my cooling fans work
They are fused, maybe you blew the fuse or relay? They are also plugged in, check the plugs.
Jul 14, 2014 | 2001 Chrysler Town & Country
Brand new mini fridge was on it's side before being set up. Plugged in too soon. Now it won't start cooling. Are we out of luck?
It could be that liquid coolant got into the low-pressure part of the cooling system when it was on its side, and is preventing the expansion valve from doing its job converting high-pressure liquid coolant to gas. My recommendation is to unplug it, wait the 24 hours, and plug it back in. Excess fluid should have drained to the bottom of the cooling system by then, and normal cooling can begin.
Dec 19, 2013 | Black & Decker Food Processors
Where is diagnostic plug on 1998 crv
the obd2 plug of HONDA CRV is below the steering wheel. please check. any other questions, you can feel free to contact the tech support 2013 Multi Diag
Sep 10, 2013 | Hayden-Harnett 1997-2001 Honda CRV Engine...
Samsung Bottom Freezer RB1955SSH not cooling after being plugged up for over 12 hours
If the freezer is not cooling, then problem relates to compressor.but still wait more 12 hours and see if it starts cooling.Basically it takes approx 24 hours to regain its cooling, once its unplugged for few hours and then plugged in.---------- So once again check after another 12 hours and see if you notice cooling.But if there is no cooling then yes its compressor issue.----------- If freezer will not start cooling, then fridge will also not start.------------ Click this link below and get more details:--------- http://technoanswers.blogspot.com/2011/08/freezer-taking-too-long-to-cool-or.html ----------- This will help, thanks.Helpmech
Aug 11, 2011 | Samsung RB1955VQ Bottom Freezer...
Freezer plug at bottom plugged. How to clean out
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 21, 2010 | Refrigerators
I.ve changed my motherboard and no longer have a 3 pin connection for the case fan on the motherboard. I know that + goes to yellow and - goes to black but where does the sensor wire go?
Hi:
An option for you is to just purchase a cheap adapter to plug your case fan into a unused power supply plug, such as one that plugs into a hard drive or optical drive.
Dec 11, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dometic NDR 1292 does not cool
Check to see if your boiler tube is hot. If it is , your cooling unit is shot. Do not plug your circuit board into 110 volt power that will destroy it. To test your heating elements you need to do an ohms reading on the elements. But I can tell you from experience if your boiler tube/ this is the 3-4" diameter sheet metal tube going up the back of the refer/ is hot the cooling unit is no good. If you would like to discuss your diagnostics give me a call.
Jerry
rvtech@myway.com
734 777 6432
www.coachtech.info
Mar 13, 2009 | Dometic NDR 1292 Refrigerator
Neither freezer or refrig will not cool.
The relay switch is plugged into the compressor and you disconnect the OLD relay switch from that and unplug ( I think it was ) 2 smaller plugs from the OLD relay switch and then replug those 2 smaller plug into the NEW relay switch and then plug the NEW relay switch back into the compressor. I hope I made sense.
Feb 28, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
