Question about The Office Equipment & Supplies
What is the error code E197 mean 0n a photocopier ir advc7260
spinal
  • 287 Answers
SOURCE: CANON IR C6800
Hello Jc.Let me start by saying that despite the fact that you have properly been specific with the error code you have submitted, Canon is "fairly" specific in regards to the amount on detail in provides. I say fairly in really loose terms. The error 602 means that for any number of reasons when the copier went to boot" (begin to start up and read its directions as to what it is, who it is, and what it is capable of, it failed to get the instruction set (or failed to recognize the instructions) and therefore said "what"?!) as the copier sought to retrieve this info from the hard drive.That can mean that the partition of the hard drive that is was looking at contained corrupt information, or there was a communication interruption, or that the hard drive is going or gone bad. I know this sounds like a bunch of technical goblidy gook but you don't want to know what the 0101 means after the 602. It may not be too bad but brace yourself for the worst. That is that the hard drive may have went wheels up, or at a minimum all stored custom information is gone. The latter may be the best you can hope for. I am afraid that a "hail Mary" might be to power the copier of by way of the rear switch (or unplug if you are not familliar) and wait a few minutes.Restart and hope for he best. Otherwise you WILL need a technician to replace the hard drive and then they will have to reload the system software. I was reluctant to respond to your request for help as I cannot "fixya" and I will get a bad grade from the guys that run this site since I left ya hangin. But I could not resist trying to help you and to at least make sure you did not get raped by some "hungry for money" company. Please at least give a decent rating and I will keep my fingers crossed for you..................SPINAL
Posted on Jan 25, 2008
checkitright
  • 1362 Answers
SOURCE: canon ir-2020 error code e197
check code here
http://www.startcopy.net/defects/ir2016_2020.shtml
Posted on Jul 23, 2008
SOURCE: System Error E197
I get that error sometimes, i called Canon they don't know any solution for that error code, i always fix it by turning off the machine and turn it back on, and it work just fine, but i keep getting it once every two week, its something has to do with the Voltage on the machine, it may not get enough power, or is getting more power.
Yara
Posted on Dec 01, 2008
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
marketex
  • 371 Answers
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Posted on Apr 15, 2009
Canon ir 7086 error code e197
Hi. I had seen that error before . When you pull out the main unit there is red cable in the back side . This is a polarity cable if it is loose. That error is shown
May 17, 2017 | Canon Office Equipment & Supplies
IR 1018. What's the meaning of error code e000197?
The error code E197-0000 (laser scanner motor communication error) may be indicated during the wait state upon power-on.Cause:The tube protecting the crimp terminal on the end of the bias cable that is connected to the transfer guide in therear side of the Registration - Transfer Assembly [1] moves downward, and the uncovered metal portion of theterminal comes into contact with the screw [2]. This causes electrical noise, leading to E197-0000.
press the helpful button and check link below
canon ir7105 error code e000197 0000
Jan 23, 2016 | Canon Office Equipment & Supplies
How can i fix an E007 error code on CANON IR 2022?
As far as i can work out, an Error Code 007 on the Canon IR 2022 photocopier means there is a problem with the "Fixing Assembly".
To reset the code hold the * key then press 2 & 8 keys at the same time.
If it reoccurs then possible reasons for the error are a torn sleeve in the mechanism or the film roller is not working. To fix means disassembling the fixing mechanism. If it is a ripped sleeve then replace it. If it isn't then try greasing the roller mechanism.
Just to note that it is maybe a good idea to clean the all the temperature sensors with ethyl alcohol while you have the unit apart.
Sep 18, 2014 | Canon iR 2022i Printer
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
Error Code E000197
check the flat cable of dc controller to main drive pcb
Jan 13, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Hello I have a canon ir2022 copier. I did a complete cleaning of all copier and when I recovered after having switched on a message error code e197. I controlled everything but I can not get from this...
Dear Mokhtar,Error code E197 indicates that laser scanner does not work properly. It's seems that you should try to replace this parts (Laser Scanner Assembly). Please download the following piece of IR2022 parts catalog to see detail of laser scanner assembly:Laser Scanner Assembly
I'm sorry for being late responding your problem and you don't have to pay for this :).
Regards,Xanda
Oct 03, 2011 | Canon iR 2022 Printer
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Mf8180c error code e 197
I believe a E197 error refers to a power problem relating to the fuser. I would remove any covers to access the fuser, remove it and reseat it and any nearby connectors.
Feb 25, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
26 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
