Question about Nuvico Televison & Video
I am trying to get a hold of 2 pieces of Nuvico EZdome5 main boards NU1301, cODE NO. 33400038. Will appreciate if I can get some guidance.
Lg 42ld520, audio is ok, picture has issue. While watching a program, screen became darkened, horizontal lines, wavy split images. Repairable or replace? any guidance would be appreciated.
90 percent of the problems with flat panels comes down the power supply board. Without this actually in my shop there is no way to know for sure but I would try that. If you take the back off you will find the main PS board. Get the numbers off of the board and do a search for the replacement. A great resource for this is Allied Electronics. I use them all the time. The price of the board should be pretty inexpensive so no losing much if you try it out. Good luck.
Dec 05, 2014 | LG 42ld520 42-inch 1080p 120 Hz Lcd Hdtv
I have a Nuvico 16000 Getting error message "Check the system: HDD Help!
The user manual does not help with this error. Sometimes there is a reset procedure, but I could not find something like that.
Perhaps you try to get some support form Nuvico on this page:
Nuvico
PS the manual is still online.
Nov 20, 2014 | Computers & Internet
I need to reset administrator password for Nuvico ev-16000
try 00000000 and then hit menu re enter the 0000000 go to system go to account then go down to password or follow the video
Apr 13, 2014 | Nuvico Televison & Video
Nuvico ev-8000 Unit will not display vidio. Heard a loud pop and it stopped playing.
The main power regulator board has to be replaced as card basis.
Aug 19, 2012 | Televison & Video
Sharp lc 60e88un shutdown the 24v from power board no 12v
to check for led eror vol_ channel+ hold and press power switch once andrelease only power switch triangle light should come on then release the vol and channel knobs if set comes on the leds defective in screen
Mar 02, 2012 | Sharp LC Televison & Video
Lights flashing under spin cycles , and programes will not operate
Either the motor or the main control board (could be both) has a serious problem.
However, it can also occur if there are spikes in the mains and it upsets the control board.
Try clearing the error code table and reset the control board.
Turn the knob to the off position.
Wait 2 seconds.
Turn the knob to the 6 o'clock position.
Wait till the start light flashes.
Wait 2 seconds.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Release the spin button.
This should clear the error code table.
Turn the knob to off.
Turn on and try the machine again.
Try this a few times.
It should clear the fault code but if the control board or motor is still faulty, it will detect and show the code again.
Jun 15, 2011 | Washing Machines
How can I convert the Nuvico NVJV 8000 from NTSC toPAL?
I have the DV3-8000; the service menu can be accessed by holding down keys 1 and 3 simultaneously; there is an option to select either NTSC or PAL; my GUESS is select PAL; don't know if there is more to it than that, but this is a start . . .
Jul 28, 2010 | Nuvico NVJV-4000N Video Recorder
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
Apr 22, 2010 | Nuvico NVDV3-16000N
Problems with a dv3 16000 Nuvico digital recorder
did u try using a cd cleaner the dvr only accepts cdr not dvd try using the usb port with a thumb drive to see what happens
Jul 05, 2009 | Nuvico NVDV3-16000N
Televison & Video Logo
22 people viewed this question
Top Nuvico Televison & Video Experts
Are you a Nuvico Televison and Video Expert? Answer questions, earn points and help others
