Question about Sewing Machines
Reverse button on my ExcelPro 5124 does not work can I correct myself or take to service person?
2 Suggested Answers
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
Reverse does not work on my New Home Janome Excel 23L
it will only reverse in straight stitching if it's not reversing at all,I'd return!
Jan 15, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Dogs motor?
Does it have a stitch length dial which ranges from 4 down to 0 and then into negative numbers? If so, the negative numbers will be reverse stitches. Some machines have this functionality and its very happy for doing mending or stitching in awkward places to sew backwards without having to hold the reverse button.
However, if yours is only sewing backwards when stitch length is set to 2, 3 or 4, then its probably a drive problem internally. Don't think your machine has a seperate motor for the feed dogs, probably a gear driven shaft in the free arm.
Dec 06, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Bobbin jamming immediately on my my 5124. Can't
Recheck the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the proper guides.
Re-thread the machine with the presser foot up.
Make sure the needle in inserted with the flat side to the back of the sewing machine.
Feb 28, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Backstitch isn't working
First, ensure that you are pressing the reverse lever all the way in and holding it. A light touch won't work on this model.
There is a spring loaded cam in the feed system which can get gummed up when the lubricant gets old. It needs to be carefully taken apart, solvent cleaned, re-lubricated and reassembled. A knowledgeable repair person needs to perform this operation.
Feb 21, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
