Using jmb model jto12600102b as computer monitor. If left or 2 min it turn's off,can i stop this
What wireless adaptor fits a jmb tv
Microsoft retune jmb tv Network & Wireless Adapters ... - Fixya
www.fixya.com > ... > retune jmb tv > Network & Wireless Adapters
Microsoft network & wireless adapters retune jmb tv related questions and answers. Ask your Microsoft questions. Get free help from network and wireless ...
Will a wis09abgn wireless adaptor work on my jmb.please ...
www.fixya.com/.../t26040126-will_wis09abgn_wireless_adaptor_work
24 mins ago - will a wis09abgn wireless adaptor work on my jmb.please - Network &Wireless Adapters ... wll an wis09abgn wireless adaptor fit myJMB tv.
Buy TV Cables & Adapters from our Television Accessories ...
www.tesco.com > ... > TVs > Television Accessories
Tesco PLC
Jan 05, 2016 | Televison & Video
Jmb tv troubleshootingMy jmb tv won't turn on. The stand by flashed a few times and the tv turned off and will not turn on. No response at all. I have changed the fuse but still nothing. Model no,...
Hi , silly question but I have a jmb tv 32 inch code Jt0132003B/01 but can't find the power button on the tv !?! I looked all over the tv but doesn't seem to have one ??? I don't want to leave it on stand by so my only option is to turn off at wall but that turns off My talk talk and DVD player too , any know where is it !?!
Apr 19, 2014 | Televison & Video
JMB Television volume keeps switching off
If it works about 10 minutes and shuts down gradually, the fault must be with its audio output IC. Replace it.
Jun 30, 2013 | Televison & Video
I have a Dell Inspiron 531S, I have both two different monitor slot, does my PC support dual monitor systems?
Yes.
The area on the back of the computer, that has two ports to connect a monitor, is a Graphics Card.
It is a PCI-Express graphics card, and is plugged into a PCI-Express x16 slot on the motherboard.
(Expansion Slot)
It has a blue VGA port, white DVI port, and black S-Video port.
The area on the upper left with a blue outline around a VGA port, is a VGA port connected directly to the motherboard. It is Integrated Graphics.
You CANNOT use Integrated Graphics, and a graphics card at the same time.
It's either use the Integrated Graphics VGA port, OR use the graphics port/s on the graphics card.
BIOS will Not support using both Integrated Graphics, and a graphics card.
HOWEVER, you can use the VGA port, and the DVI port when using two monitors.
You will be only using just the graphics card.
Example of a VGA port, (Connector), and VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
Example of a DVI port, and DVI cable,
http://en.wikipedia.org/wiki/DVI_connector
1) Whatever monitor you have that has a VGA cable, plug it into the blue VGA port on the graphics card.
(There are VGA monitors {CRT} that resemble a small TV. VGA cable is usually attached.
There are also LCD flat screens that have a VGA connector, for a VGA cable, and may also have both a VGA, and a DVI connector.
To digress for a moment;
VGA is Analog. It uses an Analog video signal.
DVI is digital. It uses a Digital video signal.
A computer naturally puts out a digital video signal. This digital signal has to be converted by the computer, into analog for an analog monitor. This slows the graphics process down. This is one reason it is best to use digital )
2) Plug a monitor with a DVI cable into the white DVI port on the graphics card.
3) Turn the monitors on.
4) Turn the Inspiron 531s on.
5) When Windows has loaded, right-click on an empty area of your desktop computer screen.
Now left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
6) You are now looking at a small window that has two monitor icons in it.
Monitor 1 icon, and monitor 2 icon.
Monitor 1 icon is your Primary Display.
Monitor 2 icon will be for the Secondary Display you are adding.
Note how monitor 1 icon is sitting to the Left, and monitor icon 2 is sitting to the Right.
This is how your monitors are supposed to be arranged on your computer desk.
If the second monitor is on the Left on your computer desk, you need to move the icons around.
Move monitor 2 icon to the Left.
Left-click on the icon, hold the left mouse key down, and drag the monitor 2 icon over to the left side of monitor 1 icon. (All the way over, or it will snap back to where it was)
It may matter to you how your monitors are arranged. It may not. Once you read the following it may help you decide.
7) Left-click on monitor icon 2 if you have not already done so.
Go down to where it states, "Extend my Windows desktop onto this monitor"
8) Left-click once in the empty square, to the left of Extend my Windows desktop onto this monitor.
9) Now left-click on Apply at the bottom Right corner.
10) Finally left-click on OK at the bottom Left corner.
You should now see your desktop screen on both monitors.
When using the internet on both monitors, you have to drag the screen from the Primary monitor to the Secondary monitor.
Go to the left side of the screen. Left-click right on the edge of the blue frame. Hold the left mouse key down after you click, and drag the screen across to the left.
Doesn't work?
Go to the right side, click on the blue frame, and drag the screen to the right.
This is why it may matter how the monitors are arranged on your computer desk.
It's kind of eerie your first time dragging the screen across.
You will also find out why it is best to use two similar monitors, when using dual monitors. The pixel resolution is different for both monitors, if they are different from each other.
For additional questions please post in a Comment.
Regards,
joecoolvette
Just to add:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Screen Turn's on.You seen Acer load up Splash Screen for less then a min, Stay on until Windows Xp Load up screen then goes into sleep mode. Encontered same problem when I connected Xbox360 with HDMI to...
  • Hello chaleebradsh, the "Monitor" as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. "I hope this information is of help; thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer AL1717 17" LCD Monitor
How do i get it to stop powersaver at start up
its not the monitor.. it is your computer's power saver option. If you are using XP, start--->go into control panel----> power options and there will be options for different thing... find where it says turn off monitor after 15 min and make it to any time you want. Also same in vista and windows 7..
Good Luck
Nov 28, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
TRYING TO CONNECT TWO MONITORS FOR EXTENDING USE
1) You have to have a graphics card with two monitor ports.
You Cannot use one port on a graphics card, and the VGA, or DVI port on the motherboard of the computer.
BIOS will only let you use the graphics card, or the Integrated Graphics.
2) Using a 'splitter' cable results in very bad graphics on two monitors, or no graphics at all.
3) With a graphics card installed that has two monitor ports on it, connect the monitors to the graphics card.
[ The graphics card can have a VGA port, and a DVI port. Or the graphics card can have two DVI ports.
VGA = Video Graphics Array
Photo of a VGA port,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Photo of a VGA cable,
http://en.wikipedia.org/wiki/File:Vga-cable.jpg
DVI = Digital Visual Interface
Information about DVI showing a DVI cable, and connector examples for the DVI port on a graphics card,
http://en.wikipedia.org/wiki/Digital_Visual_Interface ]
4) Turn the two monitors on once they are connected to the graphics card.
Turn on the computer.
5) Windows loaded, right-click on an empty area of the desktop screen.
6) In the list go to the bottom, and click on Properties
7) Click on the Settings tab.
8) You will see two monitor icons.
One icon has a square with a 1 in it.
The other icon has a square with a 2 in it.
The 1 monitor icon is used to represent your Primary monitor.
The one you have been using.
As you can see the 1 monitor icon is sitting to the Left.
This is how your Primary monitor should be sitting on your computer desk.
The 2 monitor icon is used to represent your Secondary monitor.
The one you are going to add.
As you can see the 2 monitor icon is sitting to the Right.
This is how your Secondary monitor should be sitting on your computer desk.
Left-click on the 2 monitor icon.
Go below in the Display Properties window, and view where it states -
There is an empty square to the left of it.
Left-click in the empty square.
Now go below to the Right, and click on - Apply
Finally go below to the Left, and click on - OK
Your desktop screen will now be on your Secondary monitor.
Whatever is on your Primary monitor, has to be drug over to the Secondary monitor, when you are on the internet, or a program. (Such as a game)
Go to the blue frame on the Left side of the Windows screen.
When your cursor turns into a double-headed arrow STOP.
You'll find it's a little tricky your first time, keeping your cursor into the position where it turns into a double-headed arrow.
With the cursor in a double-headed arrow, press the left mouse button down, hold it down.
Drag the monitor screen to the Left.
Keep dragging until the window on your Primary monitor is on your Secondary monitor.
It's helpful you'll find to have two of the same size monitors.
I have found occasion where when using the internet on two monitors, that I had to Restore Down the screen, THEN drag it over to the Secondary monitor screen.
(Icons at the top right of the monitor screen.
Minimize ( - ), .......Restore Down/Maximize, ...........Red X
Then I Maximized the screen
For further questions please state in a Comment.
(Believe upper right of your page. - Comment
Nov 02, 2010 | Computers & Internet
Monitor shuts off after inactivity
Hi maggieis,
I wouldn't worry about your monitor powering off after 30 min. It's just responding to the power management settings that are configured from within Windows.
These settings can be changed so that your monitor always stays on (if you want) but the current setting is set to help save energy by turning off the monitor when no one is using the computer.
So, no worries...that's just normal Windows behavior.
Hope that helps,
Michael
Nov 19, 2008 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
