Question about Garden
X500 mower, replaced battery, plugs, and fresh gas, will not fire. Anything else I need to replace?
FRANKSFIXIT
  • 72 Answers
SOURCE: Not getting any fire
Almost 90-95% of all the Genset problems found by the factory approved Genset Service Centers are related to the fact that people don't read the OWNERS MANUAL first, and just didn't put OIL in the Genset (or the right amount) - as they are shipped from the MFR without OIL in the units to begin with!!!!
And here I thought everybody KNEW THAT!!
I guess sometimes you just have to ask the most OBVIOUS ??'s first huh (dumb as " it " may sound)?
If you bought your Genset from other then a Home Depot Store, and it's still under warranty - then you will have to contact that outlet, and see what they have to say or hopefully can do for you.
Esp all those Gensets that are Made in China and have flooded the USA market in the last 10 years or so - no thanks to our representatives in WASH DC that's for sure. It's a wonder this country even functions with all this "inferior" Made in China JUNK that keeps prematurely failing before it's normal time. Sad to say the least!
Some other obvious things to CHECK for that may be the cause of a NO start condition even after adding proper gas & oil to the brand new Genset:
1 - Some Genset gas tanks come with a gas cap "blocking insert" under the gas cap that should be removed according to your manual if it states this. (Read manual section on "First Time Starting")
2 - Is the gas tank shutoff valve FULLY OPEN? By the same token (even if the Genset is or isn't brand new) does it have an in-line fuel filter anywhere in the gas line? If not then esp read #5.
3 - Is the RUN SWITCH set to ON or RUN position (this is purely an "Electrical Switch" btw)? Is it working properly? Test it using a known good quality DVM or OHM meter! It's contacts may have become tarnished just from sitting around too long? Esp where you have saltwater conditions in the surrounding air!
4 - Is the choke being set to the proper position with or without using Ether spray to the Carb?
5 - Does the Carb have a Yellow or Black wire coming off of the bottom of the Float Bowl? This goes to the GAS CUT OFF SOLENOID mounted in the Main Jet inside the Float Bowl. NEVER CUT THIS WIRE as some know-nothings have suggested here and elsewhere in postings, as there are better ways to test the solenoid without doing that! If equipped with one - This anti-dieseling solenoid has to work properly or else flooding will occur with the gas shutoff valve OPEN.
6 - VERY IMPORTANT - Is the Float stuck in the CLOSED position not letting gas into the Main Jet? You might try and TAP CAREFULLY on the bottom or side of the Float Bowl with a hard rubber hammer first to try and see if you can dislodge the stuck Float inside. If there is a WIRE at the bottom of the Float Bowl on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER HAMMER - as you WILL damage it! If this dislodges the stuck Float then your problem is solved! NEVER FORCE ANYTHING!! It's possibly that you might have to loosen slightly and/or totally remove the Float Bowl (usually 2 screws) to see if indeed any gas is getting inside to the Float at all. If gas comes out readily but still no gas is getting into the Main Jet and intake then you purely have a DIRTY CARB issue and nothing more! If you're not smelling gas through the air filter box then you are FUEL STARVED. ALSO - Many a brand new shipped Genset will have some kind of NEW gas tank (usually metal gas tanks only) MICRO DEBRIS inside the tank itself or even in the rubber gas line (I've heard of this before, and seen this myself 100's of times with cheaper rubber hoses). That is why an added in-line FUEL FILTER (if your Genset has none) is SO important!! Usually a common $2-3 item at any auto parts store. Once gas is added to the tank all this micro debris is set free to enter into the CARB FLOAT BOWL, and that is where Carb problems will start - even with a "brand new" never run before Genset!!
7 - As dumb as this next ? is to ask I have to ask anyway - Are you getting GOOD spark at the spark plug? Some units ship with the spark wire cap disconnected and it may look like it's on the plug, but in reality it really isn't fully connected! If you are getting a good spark then it's highly unlikely that the Maintenance-free Magnetron® electronic ignition would be bad. Fouled spark plug - YES - bad Maintenance-free Magnetron® electronic ignition - hardly.
8 - If your Genset is used and said to be ? years old, and it just indeed might have some high RUNTIME HOURS on it - it just could very possibly be what sounds like to me (and I personally HAVE SEEN this happen myself firsthand) that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER or CUTOUT on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
If you unscrew & remove the Generator brushes for servicing yourself, and they are indeed below the recommended length (or worse case they are indeed totally worn down) then that most likely is your starting or output problem right there. If you are having Output problems as well.
If you choose to replace the old brushes with new ones yourself - be very careful when seating the new ones - as to their insertion and cap retainer tightening. Never over-tighten those black plastic-like brush retainer screw caps - for if you break one (hard to get immediate replacements is why), or fracture one it could cause the Genset to fail under LOAD, and that very well could do some severe damage to the generator part itself. Take your time doing it, and be patient!!
It has to be one of the CHECK scenarios listed above, as I've covered every possible cause short of a broken wire somewhere - which in that case you will have to schematic trace and DVM or Ohm-meter out wire to wire contacts. This being the least likely scenario from experience.
If you indeed find the Float Bowl assy to be the cause of dirt contamination or varnish build-up clogging the Carb, and you need a walk-through of taking it apart, cleaning it out, and then re-assembling it again - as well as re-adjusting the fuel mixture Adjustment Screws - just give me a shout here, and I'll walk you through it step by step.
That's about all there is unless you got a Defective Genset from the start. Next stop - Home Depot!
Best regards to all with the same problems, and hope I helped you out 100% - all political humor/truth aside.
Please post me a reply as to finding this solution being the best resolve to your Genset problem there by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 08, 2008
lou5577
  • 21 Answers
SOURCE: craftman leaf blower,not starting,fresh gas,new
How long has it been sitting with gas in it ,did you have gas stableizer in it ,if not disassemble carb and reinstall it will start right up...lou
Posted on Apr 22, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Posted on Apr 25, 2010
Biggdex35
  • 333 Answers
SOURCE: Engine will not fire {no spark }
Did you sand the rust off of the flywheel? where the magneto is. And did you set it right? It has to be real close to the flywheel. The thickness of two pieces of paper. And yes the pto switch will keep it from starting. If it is ingaged it wont start. Can you hear it enganging when you connect the battery? Try turning switch on and off see if it will kick in and out. With key on
Posted on May 11, 2010
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Why wont my sabre 17.5 h cv491s lawn mower start
bad plug (replace plug), bad gas (empty gas, remix to mfg specs, refill tank), improper oil to gas ratio (see bad gas), old gas, choke in off position, corrosion between plug & plug wire (under spark plug boot (pour freshly opened coca-cola on corosion then rinse with distilled water repeat if needed)) clogged air filter (clean filter or replace). if you have visually inspected & or tried all suggusted here & still no joy, take it back to store if it is new, or take to repair shop for maintance.
Sep 04, 2014 | Garden
B and S 675 Series engine for walk-behind mower will not fire with fresh gas, new air cleaner, new plug. Full pulls on starter rope 6 - 10 times produces nothing.
check for spark
Fresh gas wont help if the Carburetor is clogged (common with this horrid Ethanol gas) Or it does not have spark
Aug 17, 2014 | Garden
Sears Craftsman mower 17hp Briggs & Stratton engine. Replaced starter, spark plug and fuel filter. Will not turn over unless jump started. When running has no power.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Aug 03, 2013 | Craftsman Garden
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Aug 21, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
May 10, 2010 | Yard Machines 155 Torque Briggs Stratton...
Non-starting Toro lawn mower
If the mower was lying up for a time you will need to remove and clean out the carburettor and fill with fresh fuel.Stephen.
Nov 09, 2009 | Garden
Mower will not start,changed plug,new gas,has fire to the plug still will not start,backfires once in a while checked the fues it is ok,it is a lx460 mod# 13AX60RH744, cleaned the points etc,
Replace the air filter. Remove the plug and try to start it. If you don’t smell the gas your problem is fuel. Most have a primer button that needs to be pressed 3 times. Remove the air filter and press the primer button to see if you squirt fuel. If it has no or little smell, continue priming and starting until you have fresh fuel. Replace the filter and plug. Disengage the pto ect ( saftys)before starting. Here is the manual Don’t forget to follow the safty startup list.
http://www.dixiesales.com/ipl/339/13ax60rg744_operators_manual_02_22_06.pdf
Aug 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Jun 27, 2009 | Garden
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
