Question about Cell Phones
Passcode is required to enableTouch ID - Cell Phones
I want to recover my apple id password
Go to apple website for apple id or password recover.
https://iforgot.apple.com/password/verify/appleid.. Recover Your Apple ID site enter your name surname and email id which you have used for apple id registration. Then click on continue this will recover your apple id.
Even searching your old email form apple also help your to find your appple id.
Once you get your apple id you can reset your passcode by below method.
You dont need security question, apple will ask for security question and you just need to answer them. I guess you forgot your apple passcode. try to reset passcode by following method
Again go to above website and enter your apple id. and then continue.
It will ask for
Select what information you want to reset.
I need to reset my password
I need to reset my security questions .
Select i need to reset my password and click continue.
then you will get following dialog box.
you will get email for passcode reset. try this i hope you can reset your lost passcode.
Here is other way to unlock your ipod iphone if you have fogot your screen lock or patten lock passcode
http://ipodtips-tricks.blogspot.com/2015/12/reset-forgotten-password-unlock-ipod.html
Jul 03, 2017 | Apple Cell Phones
Passcode is required to enable Touch ID on Ipad
This is plain and simple - you need the original passcode before you can add your fingerprint. If this was a used tablet - you can get the passcode from someone that has it - or you may be able to factory reset it using itunes and recovery mode.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Apr 27, 2017 | Tablets & eReaders
How do I recover my Apple ID
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad. This is all done on an iOS device and is often the simplest way to log back into an Apple account: Open the Settings app and scroll down and tap on "iCloud" Tap on the email address at the very top of the iCloud settings screen.Dec 23, 2014
What To Do If You Can Not Remember an Apple ID or Password
osxdaily.com/2014/12/23/forgot-apple-id-password-reset-recover/
How do recover my Apple ID Google Search
Feb 01, 2017 | Apple Cell Phones
How can I overcome hacking?
1. Use a PIN or fingerprint security ... Just go into the settings app on
your device, then the general tab and
"Touch ID & passcode lock" - from here
you will be able to turn on either a numeric
PIN or Touch ID fingerprint scanning. If you
do use a PIN steer clear of the two most
common - and therefore easily guessed -
combinations: 0000 and 1234.
2. use a longer passphrase...
If you want more security than a four-digit
PIN provides - after all, there's a one-
in-10,000 chance that someone will guess it
correctly first time - you can opt instead to
use a passphrase. To do this, go to your
settings app, then "Touch ID & Passcode"
and turn "Simple Passcode" off. This will
allow you to create a longer and more
complex passcode with upper and
lowercase letters, numbers and other
symbols.
3. Turn off notifications
4. Disable Siri
Just as with notifications, Siri can leak data
even when your phone is locked. An
attacker finding your phone unattended
can ask him/her all sorts of questions that
could reveal personal information. To put a
stop to this go to settings, then “Touch ID &
passcode” and set “allow access when
locked” on Siri to off.
Feb 11, 2016 | Apple Ipad I-pad
Can I make a new password
Yes, you can
Use passcode with your iPhone iPad or iPod touch
Set your Passcode
    1)Go to settings > Touch ID & Passcode. On devices without Touch ID, go to Settings > Passcode.
    2)Tap turn passcode on
    3)Enter a 6-digit passcode
    4)Enter passcode again to confirm Change passcode or passcode settings
    To change your passcode or passcode settings, go to Settings. Touch ID and passcode. On devices without touch ID, go to settings > passcode.
Nov 19, 2015 | Cell Phones
Why need passcode for software update ipad2?and how can we fix it?
If its asking for an apple ID or iTunes account password then you need to sign in with that. If you forgot it you can recover it using the email account you signed up with. If you have a lock code on the tabket then it may be that one. You can sometimes sign out of itunes and sign in with a new one as well. This is a security feature to prevent apps from auto updating and wiping out settings or other people screw with it.
Nov 08, 2014 | Apple iPad 2 Wifi 16GB
Cant get into my iphone how do i reset passcode without code or apple id.
  1. Restoring Original Settings, and Removing Old Passcode
    • 1 Connect your USB cable to your iPhone and your computerimage1.gif.
    • 2 Turn off your iPhone by pushing the powerimage1.gif button on the top of the phone and waiting for a slider to appear on the screen. Move the on-screen slider as directed when it appears on your iPhone.
    • 3Turn your iPhone on by simultaneously holding down the power button and the home button. The home button is the circular button in the middle of the lower portion of your iPhone face. A yellow sign indicating you are in restore mode will appear on the iPhone.
    • 4 Start the iTunes program on your computer.
    • 5 Click on the summary tab when iTunes starts.
    • 6 Click on the "Restore" button. This restores all the original settings on the iPhone.
  2. Setting New Passcode
    • 7 Select the "Settings" icon on your iPhone.
    • 8 Click on "General Settings" option and choose the option for the passcode lock.
    • 9 Enter a four-digit code that will be used in the future to unlock your iPhone. Others cannot use your iPhone without the code. Your iPhone will require you to enter the four-digit code a second time to confirm and set the code.
    • 10 Select how often you want your iPhone to require the passcode to be entered.
    Read more: http://www.ehow.com/how_5822618_reset-apple-iphone-password.html#ixzz31T6pDoiy
May 12, 2014 | Cell Phones
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Nov 10, 2009 | Apple iPhone 3G
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
