Machine is frozen, jammed - Office Equipment & Supplies
  • 70 Answers
First! Disconnect ALL sources of power and check for any stored energy in unit.
Look for any materials between moving parts and safely remove them using tongs or other tool keeping hands and fingers clear of moving components.
Posted on Apr 27, 2017
Flywheel is jammed. How can I get it going again?
Could be it's frozen due to lack of oil and cleaning. If the machine is a mechanical, try this:
It was working now it seems to be frozen the needle part wont move
If it is still hung up, then there could be thread wrapped around the handwheel or a gear may be damaged. Time for repair service.
Feb 08, 2016 | Olde Thompson PWZ500
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
Old Pfaff 130 machine partially frozen
check carefully around the bobbin holder area as fluff and threads around here are known to jam the shaft
Jan 18, 2018 | Sewing Machines
Hi I have a sanyo cash register ECR 445 it has E P--LO.C1 on it and has completely frozen the machine, it would be great if you could let us know how to get it off. Thanks!
EP LOC1 is a printer lock error. The printer is jammed. Take the paper and ribbon out and look for something (paper,coins, etc) jamming the printer mechanism
Mar 08, 2012 | Computers & Internet
F17 comes up on my washing machine half way through and the machine stops.
F17 indicates that water is not getting to the machine. Ensure:
The supply line is not kinked/jammed
Water valve is not shut off
Pipes are not frozen
If you have a basin sink adjacent to the washer you can also use that to test that the water pressure isn't too low.
You can also clean the water filter in the machine (Refer to your specific model's manual for instructions)
Zach
Feb 28, 2011 | Bosch Washing Machines
Frozen handwheel. machine has basically frozen and the handwheel is unturnable.
Check the loopers below to make sure they are not binding or jammed. Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Dec 21, 2009 | Husqvarna Huskylock Computerized 910
The machine will not agitate, before it stopped it made a high pitch noise off and on and cannot turn the tub
Is this a top loader? Something jamming the under side of the agitator? Remove it to check. If the shaft that drives the agitator is frozen--may be bad bearings (and the source of the noise). If a front loader, the tub main bearing is probably frozen, again the probable source of the noise or maybe the drive belt was slipping.
Jul 14, 2009 | Washing Machines
Roper washer frozen drive?
I would first check the lid switch and the plunger that pushes the lid switch. If both are good I would make sure the machine is washing properly. If the machine will not wash or spin you have a bad coupling. If the washer will wash then stop at the spin it is usually a bad lid switch, or transmission. The transmission will have a 5 year warranty. It is also possible that you have an object stuck under the main wash tub. You can remove the cabinet and look for objects or you can remove the wash basket itself. Good luck with your repair.
Mike
Sep 22, 2008 | Roper RAX7244KQ Top Load Washer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
22 people viewed this question
k24674
jasbo
jasbo
