MG3200-E,1,6 flashing green alternately and c flashing orange when I try to print
SOURCE: canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Posted on Nov 12, 2008
  • 1031 Answers
SOURCE: flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Posted on Mar 31, 2009
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
  • 787 Answers
SOURCE: Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
Posted on Nov 05, 2009
  • 1049 Answers
SOURCE: Pixma 4500
12 times is listed an AP position error:
Carefully slide and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaner squeegie on the printhead. This mechanism is probably stuck at its full extention rather than being back at home base. Every time you turn it on and off you should see it try to move but it will seem to be stuck. Give it a little assistance and that should release it. It can get glued up with drying ink. The mechanism that drives the sliding squeegee relies on a spring for it to return and the spring isn't strong, so the whole thing jams up...
which is probably what the code means - jammed mechanism.
Posted on Mar 08, 2010
Flashing green orange lights
There is many reasons for that,
are you printing any thing???
Just restart the printed and see if lights turned off....
Jan 20, 2014 | Canon PIXMA iP4300 InkJet Photo Printer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
PIXMA iP3300 InkJet Photo Printer: my canon iP3300 has an alternately flashing green ...
I may be that your printerhead passed away. A replacement might do the trick.
May 07, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
Will not print. says printer not responding
Canon i320 does not want to print light flashes green and orange alternatively. Please help. I tried the above, but nothing works
Apr 20, 2009 | Canon BubbleJet i320 Printer
Can't print
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
May 08, 2008 | Canon S 750 InkJet Printer
Canon Pixma MP600R shows Error Code6000. Green & Orange Lights flash alternately and cannot use any of the printer /scanner functions. Help!!
Each colour flashes alternately on a continuous basis for as long as I leave the prnter on - i.e. green , orange, green , orange, green , orange,............
Mar 28, 2008 | Computers & Internet
Canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Feb 17, 2008 | Canon i250 InkJet Printer
14 people viewed this question
