Question about Jackhammer Hammering
Does anyone deal in fairline jackhammer parts
Why cant i get my drill bit in my hammer drill?
the end either pulls out or pushes in to insert and remove drill bit
Dec 16, 2015 | Hitachi DH50MR Jackhammer
Bosch jackhammer
To long without service , or problem with a broken part ? or an problem with a electric field (slide contact somewhere ) or one of the carbon brushes is autostop activated ?
Or simple a cable break , a switch with a problem ,
Mar 27, 2014 | Hammering
Black & decker jackhammer manual
Go to the Dewalt service website at http://servicenet.dewalt.com, put your model number in the Find Parts search box and you can get the manual and parts breakdown if they are still available. You didn't list the model number so I couldn't verify if it's still available there.
Jul 24, 2012 | Electric Demolition Jackhammer
Where can iget armature or commutator for 46935 hammer
Contact Harbor Freight Tools for parts. You can also have your armature rebuilt thru Eurton Electric in California. They do a good job on the Brute armature so most likely do same for yours. Turn around time usually couple of weeks. Good luck
Oct 10, 2011 | Electric Demolition Jackhammer
Chicago 46935 armature i need 1
Chicago jackhammer 96035 is the same model W/ different accessories. Use this model when ordering parts from Harbor Freight, total cost W/ shipping and tax will set you back about $40.00
Sep 25, 2011 | Electric Demolition Jackhammer
I have a old electric 120vac jackhammer (not sure manf.)
usally their is grease packed in the hammer part,you can usally see a plastic type bung(plug)on outter casing
May 13, 2009 | Electric Demolition Jackhammer
I have had to strip my 950 breaker down as the motor was working but nothing else,the roller bearing has broke up on the con rod,the bolt which goes through this and its bush has hardly any thread left...
Unfortunately these machines are not produced any more. No more spare parts are made for them either. Unless you can find anyone with parts on the shelf, which is unlikely now, I would suggest replacing the machines. In U.K. the company that supplies Kango/Milwaukee/Atlas Copco/AEG machines is called A&M Tools.
You can get some diagrams from the Milwaukee site
On teh red header, click parts and service, then in the main reading pane click parts lists.
http://www.milwaukeetool.co.uk/int/uk/uk_site.nsf/frmIndex?ReadForm
Mar 01, 2009 | Electric Demolition Jackhammer
Hammering Logo
1,321 people viewed this question
Top Jackhammer Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Jackhammer Hammering Expert? Answer questions, earn points and help others
