Question about Garden
How do i change the lower crankshaf t seal on a trimtech XT160 lawn mower
5 Suggested Answers
  • 302 Answers
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Posted on Aug 27, 2009
Testimonial: "Thanks. It worked!"
mickey813
  • 472 Answers
SOURCE: Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Posted on Oct 01, 2009
  • 1584 Answers
SOURCE: How do I change the lawn mower blades?
If they are riveted then replace the disc....if bolted simply unbolt.
Posted on Jan 14, 2010
  • 8 Answers
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
My trimtech electric lawn mower does not start up but if you turn the motor by hand it starts up.please advise what could be the problem?
cord driven --- problem start / run capacitor
battery --bad contacts , motor bushes wearing out
Apr 09, 2018 | Electric Garden
675 Series BS lawn mower discharged oil to deck?
dip stick cap loose
lower or top engine seal leaking
valve adjustment cover seal leaking
head gasket may cause a leak but would have starting problems
lower engine seal to replace
only easy after you get the drive belt pully off
Apr 29, 2017 | Garden
Torx XT160, Timing correct, spark working. Starts and then stops splatter. Have to pull many times before starting again
Hi try a new plug you're old one could b breaking down under load also give the carby a clean:::::: blow out the Jets inside Especially THE MAIN JET ::::; IF A MOTOR STARTS & WONT KEEP RUNNING ITS A GOOD SIGN THE MAIN JET IS BLOCKED.,,,.. Cheers
Dec 28, 2016 | Garden
I need an owners manual for a Trimtech 5000 Chainsaw
Try this web site : Manuals/Lawn and Garden/Chainsaw/Trimtech 5000 Chainsaw
Jan 22, 2016 | Garden
Oil leaks out of my lawn mower with briggs and Straton crank seal
lower seal replace right away if less than one year old it is warranty one engine seal if not drain oil out the flip on side remove blade the remove blade adapter next polish the shaft with sandpaper facy way of saying just sand the shaft till its bright all the way up to the seal next take take a seal puller pull seal out have to pull hard to get it out once out install new seal to seat it take a hammer beat the seal in all around slowly until seated then re install in reverse done with seal
Aug 29, 2014 | Garden
I have a new Trimtech petrol lawnmower and can not seem to get it to switch off
check the single wire going to the coil. This is the kill wire to the switch.
Sep 03, 2013 | Garden
My bolens mower leaking oil only when running...help me please bought brand new last year..
you have to replace lower seal you have to take off blade the blade adapter then take a screw driver and slowly pry out old seal remove it take new seal cover it with oil all over completly cover all the rubber on the new seal slip down the shaft seal facing up tapit in using a hammer keep going around the seal till its seat into place replaces parts and should not leak any more
Jul 04, 2013 | Craftsman 55 Torque 158cc 22" Push Lawn...
Oil leak
lower crankcase seal!
Jun 17, 2013 | Garden
How to replace bottom bearing/seal on 20 hp kohler vertical shaft
You need to remove the engine and take out the bolts holding the upper and lower crankshaft housings together.
May 25, 2012 | Toro LX423 20HP Lawn Tractor 13AX90RS848
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
