Question about RCA Audio Players & Recorders
The rca jack broke on the back of my subwoofer. i opened up the back and what do i do next so i dont break anything
  • 189 Answers
SOURCE: subwoofer conection
Ideally you want a speaker wire to RCA adapter like this one.
http://www.crutchfield.com/S-LaUCVO5Otro/App/Product/Item/Main.aspx?I=136CLR2SW
Posted on Jan 05, 2008
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
Digital Pigg
  • 8 Answers
SOURCE: Subwoofer
You have the subwoofer plugged into ac and you see a light? parhaps the RCA cord is bad. Try another one.
Posted on Aug 02, 2008
tech48
  • 624 Answers
SOURCE: subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Posted on Nov 10, 2008
  • 11 Answers
SOURCE: Broken RCA / phono jack - where to find new part?
You can buy Panel mount RCA (Phono) jacks at Radioshack, I think a 4 pack is less than 5 bucks, That should take care of your problem.
Good Luck,
Stay Classy
B.
Posted on Apr 01, 2009
My 1000 watt amp is hooked up powers on eveything is connected to the head unit but no sound comes out the sub im thinking the rca jacks r broke
check RCA wires for breaks or bends especially if they are somewhat old and used test speakers on a 9 volt battery to see if the pop and flex and push them straight in and out to see if you hear any scratching sounds
Aug 20, 2011 | Car Audio & Video
The rca jacks for my sonance the sub subwoofer are apparently broken or loose inside. How do I get the back off to repair?
Hi
Please check this link for your problem:-
http://www.instructables.com/community/Removing-Broken-Pin-from-an-RCA-Jack/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 18, 2011 | Sonance The Sub Subwoofer
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
How do I hook it up to my Surround sound reciever?
Hooking up a subwoofer is dependent upon what hookups are availble on the receiver and subwoofer. Does your receiver have a specific subwoofer output? If so, is it set of speaker-wire terminals, or is it an RCA jack? The Wharfedale can accomodate either one of these as an input. There are four speaker posts on the back of the subwoofer, and there is a single RCA jack input.
May 16, 2010 | Wharfedale Topaz SW-10 Subwoofer
Need to hook up to keenwood powered subwolfer 1050sw and im a girl and dont know how
The receiver has a subwoofer out jack on the back. The powered sub has a LF input jack on the back. Connect the two with an audio cable that has 'RCA' plugs on both ends.
Mar 19, 2010 | Pioneer VSX-D409
Describe your Infinity RS-12 Subwoofer parts Problem. I have a Buzzing sound, I believe that one of the RCA input jacks is bad from the use of a POS Monster Cable that was hard to plug in. Broken the RCA...
Do you know for certain it is broke?
Could you have just damaged the soldering to it. RCA jack sockets are easy to get hold of at electrical parts shops such as Maplin (UK) or Radioshack (USA) or the like... You might just need to take it out to show them at the shop.
Feb 21, 2010 | Infinity PS-12 Subwoofer
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Broke ******** in amp input
    If the center conductor of the RCA plug broke of inside the RCA jack of the amplifier, you may be able to push it out from the back. If that's not possible, you may have to remove the jack from the board, disassemble it and then push the center conductor out. If you send me a photo of the jack, I may be able to offer more suggestions.
    babin_perry@yahoo.com
    Aug 09, 2008 | Sony Car Audio & Video
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
