Question about The Office Equipment & Supplies
I have error code c_0105 on bizhub printer c650 i wanted to do reset but ok button still blinks red when you want to click reset ok no sensor responds on touch screen, what is the solution?
SOURCE: Touchscreen does not respond to touch
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Posted on Sep 29, 2008
getbharti
  • 33 Answers
SOURCE: blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks ..it means the respective cartridge is bad and replace it..
if u have replaced all the cartridge..it might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it ..it will be refurbished one..
Posted on Nov 28, 2008
SOURCE: Error code C-0211 Konica Minolta Bizhub C-351
I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
Posted on Nov 03, 2009
cvyoung
SOURCE: Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Posted on Feb 02, 2010
Bizhubman
  • 108 Answers
SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Posted on May 19, 2010
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Jan 01, 2017 | Konica Minolta BizHub C650 Copier
C-0105 clear
mam
Check the paper trays 3 and 4. jam paper behind the trays????
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Bizhub c650 error code c3102
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Feb 03, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub c650 fehlercode c3102
C 3102 - Communication sistem setting error.To reset :
Turn OFF the copier,keep pressed Utility/Function key and turn ON.Keep pressed the Utility key when Trouble reset message apaire on screen.Touch the message,turn OFF ,wait 1 minutes and turn ON.
If the code persist remove the fusing unit and under fuser unit in right side upper is located 2 sensors under plastic knob.Clean the 2 sensors.
Dec 22, 2013 | Konica Minolta Office Equipment & Supplies
On the bizhub C550 an error code C0204..... won't let me use paper tray 2
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
Jul 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
