Question about Vacuums
Piles bleeding solution - Vacuums
How to use on hardwood floors
yes but if they are laminate dont use wet cleaner vac
Jan 08, 2018 | Vacuums
Powerhead won't rotate on low-pile carpet
Sounds like the vacuum is adjusted too low on the carpet. Adjust it to a higher level. If this is not the problem, then the belt is slipping. Buy a new belt.
Dec 02, 2015 | Hoover Vacuums
My dyson dc14 leaves lines on my carpet why?
Hi Geoff, it's Jack at Dyson.
To answer your question effectively we would need to understand a bit more about the type of lines your DC14 is leaving in the carpeting. The rotating brush bar sweeps into the carpet pile to remove ground-in dirt and pet hair. The bristle tufts can have the effect of raising the pile where it's been trodden flat from use. Equally, as with any upright vacuum, the two rear wheels can leave temporary impressions in the carpet pile, which may be more noticeable in deeper pile carpeting.
We wouldn't expect the machine to leave other types of lines, and we'd like to help you check the soleplate and brush bar are undamaged, and fitted and working correctly.
When you have your DC14 easily to hand, please contact the Dyson Customer Helpline. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 23, 2015 | Dyson Vacuums
Can I use dovate ointment for piles?
NO! it is a topical steroid used for treatment of ezcema and makes the skin thinner and slows down
skin regeneration..would make the healing of piles slower
and more difficult. visit your thr meantime
"Germoline" is pretty good
Dec 22, 2014 | Vacuums
Heighth adjustment
Orecks do not have any height adjustments. If you have high pile carpet and an older model Oreck, you can purchase a high pile attachment and install that on your Oreck.
Mar 20, 2014 | Oreck Vacuums
My purple Dyson Animal (without the ball) isn't working correctly. When I turn it on, the red power light, as well as the medium pile buttons flashes. When I first turn it on, the brush rotates for 3 to...
I need help repairing my Dyson. I cannot push the buttons down to select Short pile/Medium pile or bare floor. The buttons will not push down at all. It will not allow me to select anything. I have very short pile carpet so it does not pick up that well.
Oct 23, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
