I have a problem of error code c- 3B06 on my bizhub c652
Konica minolta c652 errorr code c211 - Konica Minolta Bizhub C452 Copier
Your authentication device isn't connected properly or wrong loadable driver or your mainboard have malfunctioned. I'd try re-connecting the authentication device USB connection and try new loadable driver, setup in Service mode and perhaps flashing it with latest firmware could resolve your issue. If all this fails then MFPB is to be replaced.
Sep 21, 2017 | Konica Minolta Office Equipment & Supplies
Machine has error code c-3b02
Check the fuser unit the HOT Part. ensure properly installed. could be the fuser control board or the fuser High Current coil that part the fuser sits up against.
Jan 18, 2016 | Konica Minolta Bizhub C652 Color Copier...
How do i clear a funny noise in a konica bizhub c652 indicating that there is paper jam while it is no where to be seen?
Noise and jamming to different for the noise fuser unit replacement, for the jam where does it say the paper is at???
Dec 14, 2015 | Konica Minolta bizhub Office Equipment &...
If the code is CD-211 then your main board has crashed.
Jul 06, 2014 | Konica Minolta Bizhub C452 Copier
Iam getting p21 error what can i do?
Sir/ Mam,
The P- codes in general are giving you a heads up that something is going to go soon. Most time you can live with them.This code deals with the registration of colors on the transfer belt. The belt put image on the paper and rides above the drums shine item when you open the right side door paper goes between it and the sponge looking roller.Registration is like cyan on top of magenta for purple if not you get to see both colors. Any way to get to the sensors that monitor registration requires removing the transfer belt then opening the sensor covers to expose the sensors and clean them NO LIQUIDS. Mite want a tech to come out and do this
Apr 24, 2014 | Konica Minolta Compatible Bizhub C452 C552...
Free service manual
error code c-c173 bizhub c652 wat solotion
May 08, 2013 | Konica Minolta Office Equipment & Supplies
Error code c-2163
I have a problem with bizhub C652 machine with a code C-2163
Thank you for helping me find a solution
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
Konica Minolta C652 Fax/Scan Button and User Box Button
The hard drive is not turned on. enter service mode ( utility, meter count, details, stop, 0, 0, stop, 0, 1 - this should be pressed in exact succession) then go to system 2 and look for a place where it asks you about all the installed perifferals. Turn the hard drive setting on.
Jul 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
57 people viewed this question
jasbo
jasbo
