Question about Beko Washing Machines
I have a beko DSFN1530 I replaced the fascia panel / handle section and now despite power lights on nothing happens when I press start?
  • 9 Answers
SOURCE: Baumatic BFD64SS Diswasher - power light on but can't programme
http://www.manualnguide.com/dl/12334/
Posted on Jan 25, 2009
amit1goswami
  • 81 Answers
SOURCE: dv6700 boot up problem.
Try taking the sys to the BIOS screen and set the defaults after that if the sys doesnt boot up do a system restore by going into the recovery manager page from F11 key on startup to a date when the sys was working fine. IF that doesnt work try enabling the low resolution mode from the advanced boot options from F8. If this doesnt work out than finally you will have to run recovery on the sys.
All the best
Posted on Feb 09, 2010
  • 395 Answers
SOURCE: Dishwasher won't start. The Quick Rinse light is
The light blinking indicates that the program is ready to start but has not received the go signal from the Start / Stop b utton as the switch is probably faulty.
Try to reset the machine by disconnecting the mains power, waiting at least 10 seconds and then reconnecting. Try to start the machine in the normal way and if it still will not start then it means that the switck control is faulty or the control unit has a fault.
Yo will probably have to call a dishwasher technician to rectify the problem.
Posted on Jan 10, 2011
SOURCE: Stoves E2H600- lighting behind fascia
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Posted on Jun 24, 2011
  • 272 Answers
SOURCE: The panel on my GE
May I ask..Did you follow the directions about holding the heated dry button? if it locked..this unlocks it..
Posted on Jul 06, 2011
I have a BEKO 61631 S nothing comes on ,no lights etc
The main power supply regulator board [SMPS] is faulty. Contact any service technician. Gopakumar Gopalan Google
Mar 02, 2014 | Televison & Video
No power in my beko dishwasher
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Jan 02, 2013 | Beko 24 in. D3731F Free-standing...
When i press the power button,the light stays red. after about 5 seconds, the green light flashes but returns red. nothing happens?
this is a problem in the power supply unit. check the rectifying diodes if open or shorting,check onthe filter capacitor and power regulating ic. replace any faulty component found in this section
Sep 17, 2011 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
My kenmore ultra wash instaled dishwasher wont work. The "lock on" light is illuminated and when i press any button the lock on light just flashes 3 times. i tried pressing buttons, holding the...
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Sep 16, 2011 | Kenmore 15129 Built-in Dishwasher
Suzuki rf600r,hi beam not working,bulb is ok,no power going to hi beam,,tuck left handle bar cassing of,,got power to the pass switch,,but when pressed,nothing happens,,cheak wire,all seen ok,,
suzuki rf600r,hi beam not working,bulb is ok,no power going to hi beam,,tuck left handle bar cassing of,,got power to the pass switch,,but when pressed,nothing happens,,cheak wire,all seen ok,,when main light on,and switch to hi beam,both wires to the buld go dead,,replace left hand cassing,still the same,,any ideas,or some 1 cheap to look at it,thanks,,
Jan 28, 2011 | 1997 Suzuki RF 600 R
Beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Mar 22, 2009 | Washing Machines
Dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens.
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Beko Dishwashers
Washing Machines Logo
Top Beko Washing Machines Experts
noel
noel
Chris Hall
Chris Hall
micky dee
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
