Question about Lands Phones
Gigaset c300a can't get it off two way record
2 Suggested Answers
hmerchant110
  • 7191 Answers
SOURCE: I need an instruction leaflet for gigaset C300a
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Feb 07, 2011
I have no ringtone and the phone is flashing base. All okay yesterday. I have tried it on the other base and it is the same, so I assume it is the handset.
check radio base where one of the bases plugs into phone line. Check power and check phone line plugged in properly.
All other bases are just charging phones. !
Nov 12, 2015 | Siemens C300A2 C300A-2 C300A 2 Gigaset 2...
Gigaset 8825 answers phone but does not record message
Some Gigaset phones have an option to have the answering machine play an outgoing message only without taking a message. You should check your settings and make sure you don't have yours set up this way. This could also happen if the memory for the answering machine is full so that it cannot record any more messages.
Sep 01, 2014 | Siemens Gigaset 8825 Cordless Phone
We have a A400 phone, how can the flashing red light be deactivated on the message key
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 22, 2014 | Gigaset A400 Dect Cordless Phone - Single
I have a Siemens Gigaset 8800. I am trying to record a personal greeting. (the quick greeting that it comes with is the one playing) I've followed the instructions. The phone responds "empty record
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027395.pdf
http://www.barclayent.com/manuals/Siemens%208825%20Quick%20Start.pdf
Hi please find above links for your user/QS manual.
Now if you have done it successfully in the past and you are indeed doing the exact same procedure, but it fails, then the only conclusion one can come to is that the unit has faulted? I have seen similar types of faults on these and other types before, and they always present the same symptoms you indicate. However use this top manual and go to page 55 and do that procedure, and see if that will work? If it still will not work OK, then you have little option but to get it repaired, use the process indicated in the manual, as to repair. You may like to only first just ask for a "Quote", and once appraised of costings etc, you can then make up your mind as to repair or replace?
Oct 24, 2011 | Siemens Gigaset 8825 Cordless Phone
I have a gigaset 4215 answering machine (but it says 4200 on the actual phone)...but no manual...and am trying to figure out how to record message for the answering machine so people know its mine...but...
You control the answering machine from the handset. First turn on the answering machine. Press Menu then use the up/down arrows keys to navigate to Ans Machine. Press OK then navigate to Answering M. Look for a check next to this to indicate it is on. Press OK to toggle the answering system on or off. Then press End or left arrow to return to the previous menu. If the machine's memory is full, it will switch off. Delete messages so that the unit will keep the answering machine feature on.
Next to record a new message follow the above steps to reach the Ans Machine menu and press OK. Scroll to Announcements and press OK. Scroll to Record Annc or Rec Annc Only (if no messages will be recorded). Press OK then bring the handset to your ear and listen for the notification of recording and then the tone. State your message clearly into the microphone of the handset. Press End to stop recording and listen to the unit play back your announcement. (It will stop automatically after 170 seconds or a 2 second pause in your speaking.) If an Annc Only message is available, the machine will play it when the memory is full. Otherwise, it will turn off.
To select your announcement (and recording type) follow the above steps to Announcements and press OK. Then scroll to Mode and press OK. Scroll to Annc or Annc Only (available if the Announcement only recording has been made) then press OK. Again OK toggles the announcement on or off; look for a check mark to indicate the announcement will be played. Press End to exit the menu.
Retrevo has the manual for the Gigaset 4215 here: http://www.retrevo.com/support/Siemens-4215-Telephones-manual/id/23319bh144/t/2/ . You will need to enter a code to download the file.
I hope this helps.
May 05, 2011 | Siemens Gigaset 4215 Cordless Phone
I need an instruction leaflet for gigaset C300a duo phone . can you nhelp?
Feb 07, 2011 | Lands Phones
Change recorded message
Please follow the steps:
1. Press MENU
2. To select "ANSWERING SYSTEM MENU?", press SELECT
3. Scroll to "GREETINGS?" and press SELECT
4. Scroll to type of desired message and press SELECT
5. Scroll to "RECORD GREETING?", and press SELECT
6. Record a message or greeting through the base speakerphone or base station handset. 7. Press SELECT to play back greeting/ message.
NOTE: To avoid background noise, record message through the corded handset.
Sep 12, 2009 | Siemens Gigaset 8825 Cordless Phone
Retrieving message
First set up a pin # or use the default which is 0000.
Then from a remote location:
  • Dial the Number
  • Press * Twice before the greeting is completed
  • Enter the Pin
  • Select * to hear all messages or Mailbox number which you are calling to check
  • Use the menu below:
5 - Play New Messages
6 - Record Message
7 - Play All Messages
8 - Play Greeting
9 - Record Greeting
0 - Turn System Off
# - Access help
Sep 17, 2008 | Siemens Gigaset 8825 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
