Question about Uniden DECT 6.0 Cordless Phone ID
Register handset try to register one handset of 3 ,,,, wont let me register ,,, I have no manual anyone have the answer for me
  • 69 Answers
This manual should help you
http://www.uniden.com/pdf/EZAi2997om.pdf
regards
Posted on Jul 25, 2009
How can i deregister a headset from my vtech phone model#ls6475-3. Also, is there a limited to how many headsets you can register to the base.
You can deregister all of the handsets and then register each one again for the LS6475-3. Make sure that all of the handsets are out of the base and all chargers and that the phone and all handsets are in standby. Then press and hold Find Handset on the base. When the In Use light begins to blink, release the Find Handset button. During the seven seconds that the In Use light is blinking, press and release the Find Handset button. Wait for the deregistration process to complete (about 10 seconds).
If the process fails, you may need to reset the base. You can do this by unplugging the AC power cord to the base or by picking up a registered handset and pressing Talk/Flash. Then you can try again. These directions are on page 5 (page 8 of the PDF) of the manual for the LS6405 handset. The direct link to this manual is https://cdn-media.vtechphones.com/media/p/document2/products/%7BD6DAD9B0-4C1A-4882-93D9-04124A59B629%7D/LS6405_CIB_V5_20160805.pdf . Then check that all of the handsets are in standby and not on any charger before attempting to deregister the handsets again.
You can register 12 handsets to the LS6475 base, according to page 31 of that manual for the main unit: https://cdn-media.vtechphones.com/media/p/document2/products/%7BA37C95FC-053D-4D34-B60A-EA5ED42B056C%7D/LS6475-3_UM_4_925.pdf . If you use the cordless headsets, you can register 10 handsets and 2 headsets.
These manuals can be found through the product page: https://www.vtechphones.com/pd/1603/LS6475-3-2-Handset-Answering-System-with-Cordless-Headset . The base manual is in the section under the Support & Manuals tab. The handset manual can be found from the Accessories tab. Then click on the Support & Manuals tab after clicking the link for the Handset.
I hope this helps.
May 21, 2017 | Vtech Lands Phones
Can not register handset
The handset must be de-registered before it can be registered.
Try this:
1. To de-register the handset from another base:
When the orphaned handset says "Connecting..." or
"Out of Range..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 22, 2015 | Vtech AT&T CL83213 2 handset cordless...
How do you register a waterproof phone (TWX977) to a TRS9585
Not sure if you still have this problem, but...
Basically go on you base unit, and hit "MENU/SELECT". Scroll down to "REGISTER HANDSET" and click "MENU/SELECT". On your waterproof handset, hold the "#" key until it displays "REGISTERING HANDSET". And voila! After that finishes, your waterproof handset will be good to go!
Feb 03, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Trying to register used handsets
There are a couple of things that may be the problem with this. First, are you sure that the handsets are compatable with the base you are trying to register them to? Second, how many handsets are currently registered to the base unit? You may be trying to register more handsets than the base can handle. and lastly, try doind the de-registration of the handset this way, press and hold the "End" key, while pressing the "End" key, also press the "#" key. The lcd should show two options, select "Base Unavailible" and confirm. The LCD on the handset should then say to place it in the base to register it. If that doesn't work, post with the results of trying the above steps and I will try to help you further.
Jan 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
VT2461 ADDITIONAL HANDSET PROBLEM
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
Dec 12, 2007 | Vtech VT 2461 Cordless Phone
DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Nov 05, 2007 | Panasonic KX-TG6074B Phone
Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Dec 25, 2006 | Vtech IP5825 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
188 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
