N0 signal in may tv - Televison & Video
Why does my tv say n0 signal when cable is connected?
A modern tv is in reality a computer and will only receive what the software will allow it to receive. Over time and use the software will become corrupted and need a reset or reboot.
My tv regularly says it has no signal but switching off at the mains and then back on half a minute later restores it as normal. When it begins to happen too often I carry out a factory reset and it is fine again.
Mar 05, 2017 | Televison & Video
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
N0 picture sound or menu
There is a bad capacitor or bad inverter in the power supply circuit.
Jan 21, 2013 | Element Electronics Televison & Video
What color should the fuse be inside the tv coming off the power source
usually theres n0 colored fuse its only transparent glass with fussible link inside..but insome appliances they uses band-colored fuse like resistors..but thers no big deals w/ this as long as you uses same amps rate of fuse
Apr 30, 2011 | Televison & Video
HANSpree LCD TV 37''JT02 Series Product No.(serial N0.)JT02-37E 2-006G Type-T 738 (MH17841Q) Assembled in Czeck (May 2007) Need a new mother board as the present one is faulty. Please advice availability...
Please call the given number and get support of parts availability and cost.
888 808 6789 (1-714-727-2727 outside of the US), Mon - Fri: 6am - 6pm PST / PDT.
Thanks for using fixya.
Nov 11, 2009 | Akai LCT3201TD 32 in. LCD Television
N0 or Very little backlight on Samsung SyncMaster740 17" Monitor
back light is going bad. if you see a pinkish hue on the" checking signal" box on screen when it comes on. Should be white.
Feb 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Akai TV
there was n0 earplug input, but u can use the Audio Out: RCA and u will use a earplugc0nverter t0 rca HERE
Jan 15, 2009 | Akai LCT3201TD 32 in. LCD Television
Euro-vox codes
n0 sky channel
Jun 25, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
