Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 55 inch rear projection tv red convergence screwed up
I have a Phillips 55 inch rear projection tv, the red convergence is screwed up and I can not get all the cross hairs to line up. Had this problem before and moved the input cables from Video 4 input (HD) to video 2 input and the problem went away for a while. Now the 'letter box' on the HD channels are not straight lines, and the red will not line up.
Any ideas on what to do to correct this?
  • Philips Master
  • 8,617 Answers
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Posted on Jul 25, 2009
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Phillips 55 Inch Widescreen HD TV, convergence repair, the red is off. The picture is not good. Can I fix this problem my self, and around how much will it be?
I'm assuming you mean the red light or lamp? provided you know the make and model of the TV, you can no doubt find a replacement bulb for it online.
Do a search or contact the manufacturer to see what they can do, but you should be able to do it yourself.
Oct 19, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
Oct 06, 2009 | Philips 55PP9363 55" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
I have a 55 inch phillips tv that is showing a red line and also a double figure. the red line is along the outline of persons, numbers, etc. etc.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 15, 2009 | Philips 55P8341 55" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
http://servicemanuals.vstore.ca/
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
1,491 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
