Question about Microwave Ovens
Damani oven - is there a way of increasing the loudness on the timer beeps. My oven timer beeps were loud but are now very soft
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
Way too loud beep
Not the sound normally you can NOT adjust. Maybe your problem arise in two ways: a) Magnetron defective b) Triac defective. Call to service tech for diagnose the problem.
God bless you
Jul 31, 2012 | Candy CMG7517DS 700 Watts Microwave Oven
Chef Banquet - turns off after 7 minutes? Why
It appears the problem is in the keypad controller board, it will only run for 7 minutes and give a loud beep, you need a professional for this, to assess the situation.
Mar 27, 2012 | Magic Chef MCD1311ST Microwave Oven
How do I stop the beep when food is ready (it beeps if you don't remove at the food after intervals)? Sharp R-340
I too have Sharp microwave that constantly beeps at approximately one minute intervals if the food you have been heating isn't removed. It is loud, persistent and extremely annoying. I've opened the machine to try and find the loud speaker but cannot find it (it could be built in to the circuitry?). Any help on this would be appreciated. It's a very unfortunate design flaw on what is otherwise a very good and easy to use microwave.
Jun 10, 2010 | Sharp R-340 Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Loud Bang, then Light Stays On, Can't Cook
Something has failed in the high voltage supply to the magnetron. There are no user serviceable parts inside, but there are INSTANTLY LETHAL voltages present. Scrap the oven & get a new one, they are generally not worth reparing.
Jul 15, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
