Question about The Music
How can i fix the sound on my mark 10 piano ?
Middle C on my Model #SGP-151G piano is dead. How can I fix it?
I have taken keyboards apart and reattached springs that hold keys in position, also use electronics contact spray cleaner to free up the key and switch point that activities the sound
hope this helps?
Mar 20, 2015 | Music
Hello! I have the Kurzweil Mark Pro TWOi piano. Suddenly some keys make strange sounds through the speakers, like distrortion or noise. The speakers seem to be fine, because the demo songs play perfectly....
Try to re-initialize the unit(factory reset). If the keys are the problem then the rubber key contacts need to be cleaned or replaced. Contact a local service center for help.
Dec 09, 2014 | Music
Technics PR-305 Digital Piano
It sounds like you are in need of a new piano. These are common issues with keyboards. The age is a big factor. It would cost just as much in repairs as it would to buy a new keyboard.
Jan 24, 2014 | Yamaha PSRE413 Keyboard
Playing certain 3 or 4 notes at a time causing sound of one or more extra there a quick fix?
Have a professional tune it for you. It may be that some strings have loosened/tightened.
Sep 06, 2012 | Yamaha P95 Digital Piano
Key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
Aug 26, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
12 people viewed this question
Top The Music Experts
Kyle Steven OHare
Kyle Steven OHare
Are you a The Music Expert? Answer questions, earn points and help others
