Question about Samsung Televison & Video
I have a samsung WA10V9 machine. it turns only to one side and on turning back it is stuck. it makes a buzzing sound when stuck. rest works perfectly.
SOURCE: kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Posted on Nov 08, 2008
SOURCE: Samsung HT-TX72 Making noise after 2 months
The problem is the fan in the back of the receiver. A number of people have had this same problem. Somehow the fan rubs on itself when it is at the wrong angle. This also happens if the bearings give out.
You can very easily remove the top of the receiver. There's 2 screws on the sides and 4 on the back. The fan is held in by 2 screws. It is a 50mm 12V fan that you can probably get shipped to you for under $10. I have found some online for just a dollar. Type 50mm fan into google and buy one that is 12V (0.14A).
Or you can do what I did and battle with customer service for hours and hours. You most likely will have to pay the $25 to ship it to be serviced or you will be transferred to their parts retailer who tries to sell you one for $45. Eventually, if you are persistent, you might ask for the surpervisor's supervisor and with a steady tone manage to get the Samsung Service number (888.685.1349) where the friendly service agent will recognize your struggle and justly send you a fan for free or next to nothing.
Posted on Dec 05, 2008
SOURCE: Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Posted on Sep 22, 2009
SOURCE: 37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Posted on Jan 05, 2010
  • 14 Answers
SOURCE: buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Posted on Jan 22, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Buzzing sound after TV is turnedoff
Audio output card problem. Contact any serivce technician, or authorized service center for Sony.
Gopakumar Gopalan Google
Mar 04, 2014 | Samsung 50 in. Plasma TV
My samsung top loader will only drain
Very easy repair. By dropping the hose gravity takes over allowing the water to run out. The buzzing noise is the propeller on your pump jammed.(Brawires,coins,hairpins) < common causes.. STEP 1:Drop hose down to remove water from machine STEP 2:Lean machine forward on a 45,rest machine on a chair. STEP 3:Bottom left of machine is a round black cap,remove the cap(turn anti clockwise) STEP 4: Put your fingers in the pump and pull out the coins,hairpins etc from pump. STEP 5:Turn propeller to make sure it turns freely,put the round cap back on then your done. Thanks
Jun 20, 2012 | Washing Machines
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
My Samsung YP-P3 wont turn on and it has a full battery and it was working the day before but the day before it made a buzzing sound and it froze please HELP ME
Chek out for a rest small hole on the rear/side, using a small pin hold it down for about 5 seconds. try to switch on.. itmust work.. if not try to conect to the computer and using your antivirus scan the memory, delete off any virus present. Hope this works.
Jul 01, 2010 | Samsung YP-P3JCB Digital Media Player
Whirlpool cabrio washer has stoped during the draining cycle and now just buzzes, can not turn off or get it to start back
sound like a stuck motor you should check it out and see if the motor turns these motors have cheap bushbearings that wearout once they waer out to a certain point the motor stator phisicaly touches the side of the motor and once magnetizm turns on it sticks to the side and buzzes but does not turn cuz its stuck!
Aug 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Carriage of my futura 200 is stuck
Turn off the machine, remove the Hoop from the embroidery arm, then turn it back on. You'll notice some of the hoops have an extra piece of metal that the machine identifies it with. Mine just didn't like the hoop I had on.
Jul 07, 2009 | Singer CE-200 Quantum Futura Computerized...
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Motor won't start, makes buzzing sound, motor won't kick in
Sonds to me like something is stuck in the impellaer
did a glass break in the machine lately or possible some food got stuck worst case the motor start capacitor has given up the ghost so to speak.
Jan 21, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Televison & Video Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
