Question about Vizio P2 42 in. HD-Ready Plasma Television
Same problem same thing i was watching tv and the screen went black did the unplug turn off and turn on nothing .. please help anyone
  • Adam Jerome_lagudi
    Adam Jerome_lagudi May 11, 2010
    is the unit getting any power at all to the power supply printed circuit board?
Viore led42vf80 black screen
If you have no sound and no video but you have power to the tv then you have to look at the source. Source being your Cable box. The other thing to check is to make sure that you have the proper input selected on the tv. If you have cable in Video one for example then you need to have your TV input to video one.
Nov 14, 2013 | Televison & Video
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
My 26" LCD tv has black screen When I was watching it screen went black unplug ova nite still Same thing barely see movement IN back Ground up really close so but it have sound But black screen can...
Good day!
LCD screens have very thin fluorescent light tubes. if you can barely make out an image its most likely that the Power inverter board that powers the lights is damaged.
Aug 24, 2010 | Televison & Video
LG 22" LCD Screen went white
same things happened to me...did you solve this?
Jun 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
May 06, 2009 | Vizio VW37L 37 in. LCD HDTV
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
Apr 11, 2009 | Dynex DX-LCD37 TV
TV turns on, but the only thing on the screen is Please Wait Thank you for your patience.
Mine did exactly the same thing. Sound went out then the blank screen and the message. I was told by Toshiba Tech Support that this message is only set up in the channel scanning area. He suggested a "soft boot" (meaning unplug it and replug it. Did that and nothing. Did anyone solve their problem?
Scott
scottspradling@gmail.com
Nov 17, 2007 | Toshiba 26DF56 26" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
192 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
