Question about VIA Computers & Internet
How to setup ip address in n compution device another location and another network connectio And my server in rajkot and n computing device in kolkata how to set up device via static ip
  • 196 Answers
SOURCE: How to set a static IP address in Windows behind a WRT55AG Router
Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
Posted on Feb 16, 2006
SOURCE: DPR-1260 ... prints but cannot access web config page
Keep in mind that once you have configured the wireless networking on the print server, you MUST disconnect it from the wired network. It uses the same MAC (aka "hardware") address on both interfaces, so when it tries to participate on both, it fails to be networked at all. Make sure you're only using one (wireless or wired) network at a time.
Posted on Jan 14, 2008
SOURCE: Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
do you know how to network a 7420 fax ?
Posted on Jul 11, 2008
  • 53 Answers
SOURCE: Unable to reach the device for a statics IP address fro this Zebra TLP 2844-Z printer
I work for zebra. you should user zebra net bridge, its the current network tool and the best to use
Posted on Sep 03, 2008
gripfitter
  • 557 Answers
SOURCE: I have installed the DP-301U print server on my
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Posted on Oct 21, 2009
How can I print a configuration page from the E260dn Lexmark?
Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
in the TCP/IP section.
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
Jul 25, 2012 | Lexmark E260dn Laser Printer
Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet connection...
DNS-servers translate names, such as 'www.fixya.com' to IP-addresses, because routing of IP-packets on the Internet is done using the IP-addresses, not by using the names of each computer.
If you have a router between your computers and your cable-modem (or DSL-modem), then the router can automatically supply the "Primary DNS Server" and "Secondary DNS Server" and "IP Address" to your server computer, if you configure the network-adapter on the server to "automatically obtain an IP Address".
As long as you leave your server running, the "dynamic" IP-address that it obtains will, in effect, become a "static" (namely "non-changing") IP-address.
Feb 03, 2011 | Computers & Internet
Wireless does not seem to work any suggestios
Go to HP Wireless Printing Center.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I am trying to setup my set up a Access Point at my house with the following product. a EnGenius EOC 2611P. when i set security on the device it is not sending an ip address to the computer. is there a...
Assigning an IP address to a computer is a function of DHCP. Either the access point's DHCP server much be enabled, or a DHCP server somewhere on the network to which the AP provides a path must be enabled. There should be only one DHCP server per LAN.
For example, if you have a home router handing out DHCP addresses to computers in your home, and you wire this AP to your router to wirelessly serve an additional computer or computers in a remote location, then its DHCP server should be off, because DHCP service will be performed by your home router to both local and remote computers.
However, if you connect this AP directly to your network interface and serve ONLY computers in a remote location, then its DHCP server should be on, so that it will provide DHCP addresses to the remote computers (because your network interface in general won't, unless it is also a router itself, in which case see the previous paragraph).
Aug 28, 2010 | EnGenius EOC2610 80211g Outdoor High Power...
Hi - in my three-computer, PC network environment, I just changed from a static IP to a dynamic IP situation, and can't use some of the printers. I think it's because my DP 300U print server is stuck on...
Shut down all the printers and computers.
Boot all the printers first to establishe their IP addresses.
Then turn on a computer and search the network group for what is online. All the printers should show as long as they have theit IP address.
Once their static IP is established the rest shall follow with what ever IP addresses are left. A dynamic IP setup grabs the available ip address and can conflict with a device that has that static IP if the static IP device is powered up after.
Aug 25, 2010 | D-Link DP 303 (DP-303) Print Server
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
How to set a static IP address in Windows behind a Linksys Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT55AG Router
Computers & Internet Logo
26 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
