How can I delete overlay #1:1280×720,213dpi,secure
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
How do I take overlay off my screen it says overlay#1 1280×720 DPI.
It looks like you are using an alternate keyboard. Delete or disable that keyboard to see if your problem continues.
Apr 19, 2015 | Apple iPhone Smartphone
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
All lights blinking Deskjet F2180
Welcome to FixYa!
I assume that the "Start Copy Black" light and "Start Copy Color" light is also blinking.
The product has a fatal error or the scanner bar is unable to move.
Reset the printer:
  1. With the power on, disconnect the power cord from the rear of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the rear of the product.
  4. Press the Power button to turn on the product.
  5. Wait until the Power light stops blinking. The reset is then complete.
Solution two: Make sure that the control panel overlay is installed correctly If the control panel overlay, or bezel, is incorrectly installed, the product might indicate a false error condition. If the product has not been set up before, ensure correct installation of the control panel overlay. NOTE:
If you already installed the control panel overlay, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
I hope this helps.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 31, 2011 | HP Deskjet F2180 All-In-One InkJet Printer
If I undelete a file that has been overlayed with parts of another file, will the restored file include the data of the overlayed file? If I erase (wipe - not delete) the restored file then, will it erase...
No
If the file is recoverable, then it wont effect other files.
But if the file have been overwritten, you probably wont have any success recovering them.
Piriform has a good free program called Recuva
Sep 22, 2010 | Computers & Internet
Won't open the overlay screen
You must have a heading sensor input for radar/chart overlay. (i.e. PG500)
Jun 19, 2010 | Furuno NavNet vx2 1934CBB/NT GPS Receiver
Help !\r\n
Its a known problem. You have to understand their Program Control configurations. Have you set the learning period? It will be a quite long post if I describes it here. So you can check that using this link This is the manual. Read and understand the Program Control Section.
But one more issue.
On Windows systems, screenshots of games and media players sometimes fail, resulting in a blank rectangle. The reason for this is that the graphics are bypassing the normal screen and going to a high-speed graphics processor on the graphics card by using a method called hardware overlay. Generally, there is no way to extract a computed image back out of the graphics card, though software may exist for special cases or specific video cards.
One way these images can be captured is to turn off the hardware overlay. Because many computers have no hardware overlay, most programs are built to work without it, just a little slower. In Windows XP, this is disabled by opening the Display Properties menu, clicking on the "Settings" tab, clicking, "Advanced", "Troubleshoot", and moving the Hardware Acceleration Slider to "None."
Free Software media players may also use the overlay, but often have a setting to avoid that, or dedicated screenshot functions.
After adding the program it may solve this conflict between the Adapter and the Program.
Thanks for contacting Fixya! Please be kind enough to rate the answer with a testimonial (comment) if the solution solved your issue. Feel free to contact Fixya
Jun 03, 2010 | Zone Labs Zonealarm Extreme Security for...
How do you delete files from memory
From the top overlay panel, hit the following buttons in sequence.
Data Registration
Scroll down to #8 (Clear)
Set
Scroll up to select "All"
Set and the Stop
Sep 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
Frigidaire FEF369CGSA ramge- replace clock overlay/control labels
Hi Dagmail543
You can only access the old unit by removing it from the back of the panel.Some screws and clips (base at the two sides) The clock is usually secured with screws. - remove old unit replace with new - no peel or scrape usually necessary
Regards
Aug 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Remove arrow from shortcut items
If you are referring to the Shortcut overlay, there are several methods that can remove, replace or customized it.
In Windows XP:
Perhaps the easiest would be to download, install and configure using Tweak UI for XP ;
Alternately, edit your Registry. Expand HKEY_CLASSES_ROOT. Highlight "lnkfile. Delete the Registry Value IsShortcut REG_SZ. Rebbot
In Windows Vista:
Probably the easiest would be to download, install and configure using Frameworkx’s Windows Vista Shortcut Overlay Remover .
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
