Question about Emerson Televison & Video
I have an Emerson LED flat screen TV model number LF39LEM4 A. Im having trouble with the volume. It stays really low even when you turn the volume up to 70. It says its Dolby Digital.
  • 556 Answers
SOURCE: Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Posted on Sep 11, 2007
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
dsacco86
  • 1077 Answers
SOURCE: When i turn the tv on it goes to standby right away
If not under warranty, here's what you need to replace inside your TV. Power supply board BA71F0F01042.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Right now, only Discount-Merchant has one in stock. Here's the link:
Discount-Merchant.com - Projection LCD / DLP TV Lamps - Plasma ...
I know it would be cheaper to fix the TV, than replace it.
If you end up throwing the old board in the trash, I would like to keep it if possible. Here's my e-mail, dsacco86@hotmail.com
Posted on Apr 25, 2009
  • 2326 Answers
SOURCE: model number LCT27HA36..will not turn on????
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to jah2mil@hotmail.com if you required further assistance.
Posted on Aug 18, 2009
SOURCE: remote codes for Emerson Symphonic tv?
I have a symphonic tv and a emerson universal remote cannot find code anywhere for this tv???? anyone know what to do cheap tv
Posted on Sep 06, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
I have a Lg LED tv model 47LN5750 that turns on but then stays on the LG "lifes good" screen and will not do anything more. what could be wrong?
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
I'm looking fit Bluetooth pairing codes foe an Emerson 32 inch LED flat screen TV
You didn't list your model number, but I seriously doubt that any Emerson branded television features Bluetooth.
Nov 13, 2014 | Televison & Video
How to find the pairing code
These are the codes we show for our remote programmed to an Emerson TV. I have also provided instructions on how to program the remote to your TV.
Remote codes: 632, 652, 679, 682, 692, 661, 662, 657, 658
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 15, 2013 | Emerson Televison & Video
I cant get my emerson led tv to accept any form of sorround sound
If there are RCA audio output connectors on the rear of your Emerson TV, they should direct your TV audio to an external amplifier to which your speakers are attached. You don't mention this arrangement in your description
Feb 21, 2013 | Emerson 32-inch 720p LED TV Refurbished
In ALL HONESTY how is the picture quality of a LCD 1080p Emerson tv?
Terrible, even without knowing the model number or features. Ignore the Wal Mart reviews. Don't cheap-out on an HDTV, you'll regret it. If you want a truly inexpensive superb looking HDTV with screen minimums of 60", go Mitsubishi DLP. If you must have an LCD and you want to save money yet still maintain quality, go with Vizio (120Hz or 240Hz) and if you can afford it, LED LCD.
Jun 22, 2011 | Emerson Televison & Video
Televison & Video Logo
29 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
