Question about Sharp Office Equipment & Supplies
Hi sharp AR-5520 machine Red triangle light blinking how to solve this problem
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
  • 26 Answers
SOURCE: sharp ar 5520 fault code
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
Posted on Sep 07, 2010
  • 255 Answers
SOURCE: Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Posted on Oct 23, 2010
  • 66 Answers
SOURCE: the machine indicated replace drum
Press # interupt C interupt then press 20 start 1 start, then press ca, then press 42 start 1 start you can reset your machine , if any queries please feel free to contact , rate this and please vote for this so i can become in to expert catogory
Posted on May 18, 2011
SHARP AR-5520 RED TRIANGLE LIGHT BLINKING HOW TO SLOVE THIS PROBLEM?
If the triangle of dots points upward it needs toner, if the triangle points down the machines waste toner needs to be emptied out.
Apr 27, 2017 | Sharp Office Equipment & Supplies
I have a problem with sharp AR 6020 photocopier machine that is displaying triangle and minus symbols how can i solve it
The Triangle may be the toner low light. On the older models it would look like a Triangle of stacked up cannon balls. I am not specifically familiar with your exact model.
Feb 19, 2017 | Sharp Office Equipment & Supplies
CH blinking in sharp photo copyier model AR 5520
check if the toner is insert or check the doors for the machine both the front and side door door
Nov 05, 2016 | Sharp AR-5520N
How do i attend to photocoping while red triangular light is blinking?
The triangular light means it needs toner or if there is a line under the triangle the waste toner needs to be emptied.
May 24, 2016 | Sharp Ar-5316 Advanced Digital Imager...
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
Jan 28, 2016 | Sharp Ar 5316
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
