Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Shuts off my tv makes a loud buzz sound then shuts off. Am able to turn power off on the front of tv then turn back on
  • 4,402 Answers
Sounds like the high voltage transformer
or could be high voltage off the tubes.
not a good idea to keep this running as it will cause more damage, best to have service tech look at this since it's high voltage.
Be careful. This same problem burned a mark in the Blue crt on my pro730HD. Three months and the Service Tech and Pioneer have been unable to determine the cause (they claim). In the process they have blown two more crt's.
When your tv goes off, try turning it back on using the main power button instead of the remote. The button should be behind a flip-down strip below the screen. When it is working again, look for any faint colored spots in the picture most prominent on light backgrounds. Mine is a yellow Y in the center of the screen.
If there are no spots, I would suggest you don't use the TV until you get it fixed because eventually it will damage your crt ($750). Of course, as I said, they have been unable to fix my problem and I have had no TV for three months.
Posted on Dec 18, 2007
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
Loud buzzing sound,
There are a couple of possibilities. There are some styles of TV's which have lightbulbs which project light from the back of the TV. These are big TV's but are not Plasma's.
The bulb will be behind a small square or rectangle door and can be held shut with a screw or several screws. You can get the parts Online. You do not touch the bulb without gloves or a rag. A fingerprint will make a hot spot and destroy a new bulb.
There is no adjustment with a new bulb, so they are plug and play. The buzzing is the bulb arcing. The second possibility is a meltdown in a power transformer or capacitor. The video and audio are 2 separate systems to a certain point and that is why one can work and the other can be bad.
I would do a Web search using your Make and Model and look for bulbs and Consumer complaints.
Jan 25, 2012 | Samsung PS50Q97HDX 50 in. Plasma TV
My new hdtv makes a loud buzzing sound. it is connected to directv.I used a video connection because when the hdmi is used the sound is lost when the power is turned off and then back on. The tv is a...
I have comcast and get buzzing from the box when everything is off. Do you have the option of unplugging it and having the t.v. on by itself or will the provider have to come reprogram it. If not, disconnect box to rule out t.v. before t.v. warranty is out.
Jan 31, 2010 | Philips 42PFL3704D LCD TV
Tv makes buzzing noise then picture fades and eventualy shuts off
Ur colors wheel is dead,must call tech.for this is very difficult to take out,and replaced have no tv tech. experience.Best to call tv shop service,to replaced this colors wheel,and have warrenty on it.
Jan 11, 2010 | Samsung HL-P5663W 56" Rear Projection HDTV
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Sound at power on
The sound you are hearing is the degausing coil which will vibrate for a second when the tv is turned on. This part demagnetizes the picture tube and this sound is really quite normal. Depending on the position of this coil it may vibrate against the front cabinet of the tv and may sound loud at times. If this really bothers you then you need to have the rear cover removed and have it repositioned a bit do it won't vibrate so loudly. Or you can enjoy the buzz for the short time it happens and not worry about it.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Hello to all you buzzers, I have the answer to your problem. First this is what's happening. The buzzing is coming from the power relay. It vibrates at 60hz because the power supply filter capacitor is not doing its job hence you have a rough d.c. pulse going to the relay.To solve the problem remove back of t.v. slide circuit board out (you will have to disconnect white wire from degauss coil,located on left front) look for a blue box approximately 3/4"x1 1/2" this will be the power relay. Now look for capacitor location #c622 near the relay. This capacitor should be 470uf 25v. Remove and replace with 470uf 35v capacitor, connect white degauss wire temperarily put back on and give it a spin. Hope this solves all the buzzin,robert
Jul 12, 2007 | Sanyo DS24425 24" TV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
61 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
