Question about Insignia Televison & Video
2010 Insignia 19 inch LED HDTV were is the power cord connected to t.v
Pookeybrain
  • 51 Answers
SOURCE: power not being received by monitor
RMA it if its under warranty. Throw it away if its not.
Posted on Nov 10, 2007
  • 80 Answers
SOURCE: insignia 15 inch lcd tv cant find replace power cord
part # 485-10144-00
try http://bestbuy.partsearch.com or
https://www.vancebaldwin.com
neither have it but there you go
thanks
scott
Posted on May 30, 2008
John-INSG
  • 312 Answers
SOURCE: My insignia 19 inch flat panel wont power on...
Your TV most likely requires service. You may take the unit to the retailer of service to arrange for repairs. Note: physical damage that may have been caused by the unit tipping over would not be covered under the factory warranty.
Posted on Sep 25, 2009
SOURCE: Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Posted on Feb 09, 2010
SOURCE: trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Posted on Feb 22, 2010
How do I download a manual for my NS19E310NA15 LEDTV?
Hi
The link I give below takes you to a page from which you can download a pdf (Acrobat Reader) file which will save to your computer for future reference, or an HTML version which will open in your browser:
Insignia 19 inch Class 18 1 2 inch Diag LED 720p 60Hz HDTV
Good Luck
Nov 15, 2014 | Televison & Video
Pogram my suddenlink remote to my 42 inch led insignia tv
Hi - I'm Tina from Suddenlink. Please check our help site with information and codes for programming Suddenlink remotes: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx
Aug 17, 2012 | Insignia "- Connected TV 42"" Class - LED...
Remote code for my new insignia 19 inch tv using a verizon remote
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 10, 2010 | Insignia 37" LCD Flat-Panel HDTV
Feb 08, 2010 | Insignia IS-LCDTV32 32 in. Television
My insignia 19 inch flat panel wont power on. It tipped over on it;s back and hasn't powered on since
Sep 23, 2009 | Insignia NS-LTDVD19-09 LCD TV
Televison & Video Logo
35 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
